Wheel Alignment specs and details after installing the Comptech springs
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I just had my alignment done after installing Comptech Springs. The following are the details:
Before
Camber Caster Toe Tire
-1.4 2.4 -5.3 L/F 0.4 2.0 -0.29 R/F
-1.8 .20 L/R
-0.4 -0.10 R/R
Specified Range
-1.0 to 1.0 for L/R front camber
-1.0 to 0.0 for L/R rear camber
1.8 to 3.8 for L/Rfront caster
-0.08 to 0.08 for L/R front toe
0.00 to 0.16 for L/R rear toe
As you can see the Toe was way off. The rear Cambers are not adjustable, and since I am only a little off, I'll wait to get a camber kit.
2000TL, Nighthawk Black Pearl, Comptech springs and sways, 35% tint, rear spoiler, Kicker Amp/SUB added to Bose system, Optional Factory Chrome Multi Spoke 16" Wheels
Before
-1.8 .20 L/R
-0.4 -0.10 R/R
Specified Range
Originally posted by veloce:
do you have to get an alignment done when you change the springs? camber kit?? what else? is it all worth it?
The car looks so much better and I also added sway bars at the same time. The car almost handles like my BMW 3 series; it's great!
BlackTL2K, did you do the alignment immediately after putting on the springs? Looks like only the camber on the left side of you car is off. Is the left slightly lower than the right? I just had my Comptech springs put in last weekend and I'll probably get the alignment done in a week or so. The springs really feel great.
2000 Acura 3.2 TL (Nav) Nighthawk Black Pearl
I'm almost done changing the springs on my CL-S and with the front shock/spring assembly off right now, I can just grab and move the toe setting to whatever angle I want. So I'd say an alignment is mandatory after new springs are in.
Also, I've noticed that the new springs in the rear are so compressed, that they don't fully extend to the top of the rear shock assembly *when the rear is completely lifted off the ground*. When the car is lowered from the jack, there's a chance that the top of the spring may not be centered properly in the top part of the shock/spring assembly. That means it could catch on the edge of assembly, which would make that side of the car slightly higher (along with any resulting alignment issues). After seeing this, I'm going to take a quick look at the top of the rear springs with a flashlight to verify things are centered anytime the rear has been completely lifted off the ground. The fronts won't experience this issue since they're fully extended in the assembly. BTW, the springs I'm using are the H&R OE's.
Guest
Posts: n/a
Based on what I have seen with Comptech springs there is a minor amount of settling however this could be attributed to the bushings flexing as much to the springs settling.It is very important that you get the car aligned as the front toe in particular is way out of spec.The rear camber typically either falls in the acceptable range or is out a few tenths of a degree,this is acceptable and should not cause any real tire wear.I do recommend to our customers that they do keep an eye on tire wear make certain the tires are inflated properly.Jens
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
I bet your car are pulling (drifting) towards the right side.
1996 Acura 2.5TL white
*Alpine 6 disk CD changer
*Factory wood kit
*Factory burlwood shift knob
*HKS power flow
Before
-1.8 .20 L/R
-0.4 -0.10 R/R
Specified Range
Before
-1.8 .20 L/R
-0.4 -0.10 R/R
Specified Range
*Factory wood kit
*HKS power flow
Zonian22
11-14-2015 01:20 PM
nuldabz
09-03-2015 05:49 PM
Zonian22
09-02-2015 08:19 AM
