whats this code???????
Old Dec 23, 2005 | 09:56 PM
bkzjimmy's Avatar
NiGhT rIdEr
0600...i think that was it, my CEL was on.
Old Dec 23, 2005 | 10:13 PM
Pure Adrenaline's Avatar
Dragging knees in
That codes is for Serial Communication Link Malfunction.
It didn't have a subsequent code error, like 601 or anything?
Old Dec 23, 2005 | 10:14 PM
bkzjimmy's Avatar
NiGhT rIdEr
that like speaking ALIEN to me....
Old Dec 24, 2005 | 01:00 AM
dvsxlt247's Avatar
99TL-p 114K
What exactly does that code mean?
Old Dec 24, 2005 | 05:18 PM
phipark's Avatar
Not Asian
I think he means, was there any other code. The code that you threw probably is a certain series of codes/problems. There should be another code that contains further details.
Old Dec 25, 2005 | 01:21 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Was it P0601 P0602 P0603?
This is probably a problem with the PCM. Hopefully they'll replace that for free as a part of the transmission, but it seems like someone else had the PCM go bad recently and it was something like $900 and Acura wouldn't do anything for him.
Old Dec 26, 2005 | 10:27 AM
bkzjimmy's Avatar
NiGhT rIdEr
what is PCM, what does it do??
Old Dec 26, 2005 | 11:15 AM
Dragging knees in
Powertrain Control Module... or more commonly known as the ECU.
I was asking if there was another code with the P0600, because I think it indicates where the communication link failure happened. The PCM communicates with many different parts of the diagnostics system, and if there's a communication failure, it should say where that happened.
Old Dec 26, 2005 | 11:41 AM
Dragging knees in
I just checked with a friend.
The code indicates an external problem. In other words, there's a OBDII port communication failure with the scanner. It could be a bad scanner, bad connection, or something else.
It reminds me last time I had an O2 sensor failure, I hooked up a scanner to the port and it had an error. I simply tried again, and it went through. So give it another try. If it still doesn't work, then try a different scanner.
Good luck, and sorry about the misinformation above.
Old Dec 26, 2005 | 02:06 PM
bkzjimmy's Avatar
NiGhT rIdEr
thanx alot
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
