What type of coolant in our car?
Just wondering, since somehow i misplaced the manual. I know i know.. its a newb question, but can someone answer it???
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Also use the honda fluid, it cost more like $14/gallon but there seems to be something in there that most of the other fluids have. silate or something like that... if you read it, the honda/acura doesnt have it. it is 50/50 pre-mixed but most of the autostores ones are little -silate or has silate. I know my spelling is off but what it is supposed to do is over time cause damage to the system.
I am sure someone else can verify.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I just didnt want to take the chance just for $8 or so.
Page 238 of the manual that you can download from www.acura.com
"Always use Honda All Season
Antifreeze/Coolant Type 2. This
coolant is pre-mixed with 50 percent
antifreeze and 50 percent water. It
does not require any additional
mixing. If it is not available, you may
use another major-brand non-silicate
coolant as a temporary replacement.
Make sure it is a high-quality coolant
recommended for aluminum engines.
However, continued use of any non-Honda
coolant can result in
corrosion, causing the cooling
system to malfunction or fail. Have
the cooling system flushed and
refilled with Honda antifreeze/
coolant as soon as possible."
http://www.team-integra.net/forum/di...PagePosition=1
If you search for silicate you'll get to this post
"It may also be wise to suggest the use of non-silicate coolant. Honda like many other import vehicles with aluminum parts should consider using this type of coolant as suggested by honda. Silicates over time act as a sand blaster to your water pumps and radiator, eating away at it. I honestly cannot say I have seen a failure due to this in person, but I have read much on the subject and feel it is a worthwhile investment to prolong the life of the cooling systems by getting the closest thing to meet honda specs.
Honda coolant is expensive and supposedly lasts 60,000 miles and is good stuff. Zerex G-05 is a new product and is a good alternative as it is the closest to conform to Honda specs and is much sought after by owners of European cars. Another option is the Extended Life coolant such as Zerex 5/150, but that would require you to fully flush the coolant system first since it is not compatible with the green stuff, but is phosphate, borate, and silicate free. Do not mistaken this for Dex-cool, even though it is similar in color. It is Dex-Cool compatible, but is not Dex-Cool by any means. Dex-cool turned out the be some bad stuff and would precipitate in cooling systems and clog heater cores."
GO-5 is a low silicate antifreeze! Here are ones that are phosphate free/silicate free
http://www.valvoline.com/pages/produ...asp?product=11
http://www.peakantifreeze.com/pkextended.html
Originally Posted by VTEC11
How about prestone is that okay? Do they make a low silicate based coolant?
~Whatever~
Has anyone registered with this owner link
You can request a copy of your owner's manual as well review the preventive maintenance.
:brakejob:
if you buy the coolant from honda (acura always seems to jack the prices, at least here in the sf bay) it's almost as cheap as regular prestone... just go with honda...
MANY service people I know across all walks of car brands will say "blah blah fuck <insert car brand here> just use castrol/fram/champion/purolator/valvoline for your x/y/z," because they say the manufacturer is full of crap, but no matter what they ALWAYS say to use their own brand's coolant (except for Ford because they reformulated sometime back and the old stuff is not as availble for older cars)... acura always says use honda ATF though, and i follow that to the letter
:brakejob:
Originally Posted by hangbok
How much does the coolant go for at honda? Also how much would i need if i want to flush my radiator and to fill the reserve. Thanks.
You need a silicate free formulation....Look for Prestone All Makes/Models, it is silicate free and works well with almost all cooling systems. Although it is not Dex-Cool certified, it will still work well in those applications.
Many people misunderstand the DexCool problems that GM had...it had nothing to do with the coolant...it was customers who failed to change the coolant regularly, and failed to keep it topped off combined with lame gasket materials used with GM.
Just make sure that when you switch, you completely flush the system as different coolants don't seem to mix too well, from experience.
Michael
Michael
Look Mean, Play Nice
I noticed my coolant level was a little low so added some regular 50/50, should I flush out the entire system and replace it with a non-silicate formulation?!!?
Update: Decided to flush the system after reading something roadrage wrote about different coolant brands gelling in the engine. 90 bucks better safe than sorry.
handsom-hustla
11-13-2015 05:04 PM
