What should i do?
What should i do?
Hey, i'm new here. I drive a 2002 Nissan Maxima SE 6-speed, but my father drives a 2000 Acura 3.2TL. My dad was debating whether to keep his TL with 75,xxx miles or to get a new 07 TL and decided to keep his car. however, he wants to go through every bit of maintenence on the car and put it into like new condition. So i am going to detail the car inside and out myself, but my dad is also giving me $1500-2000 to spend on making his car nice. I just wanted to know what you guys think I should do the car with that amount of money. I am definitely getting him a new headunit for the bose (his isnt reading burned CD's)...probably an alpine 9856 (i have it in my car). was going to drop it and not let it look like a 4x4 anymore. I would appreciate some suggestions on what to get. thanks a lot
Mark
Mark
If you want to make his 00 TL better than new at 75 k miles:
Seafoam the engine, Change the Plugs, Install Racing Brake rotors and Hawk pads from vendor Mr HeelToe.
Check the tires
Change the engine oil/filter, do a trans flush. Install K&N air filter Bosch Icon wiper blades
Thats about 7-800 for everything you need to do.
These cars dont even need timing belt and water pump until 105- so put the leftover money in a savings until needed
Dad made a good decision to keep a known car with less problems than the new cars
Check the tires
Check the tires
Check the tires
Lowering it will reduce the ride quality, which can be balanced out by better shocks
That will take your grand no prob.
You can remove the acura and TL badges on the tail and replace with Japanese versions which say INSPIRE they are in english www.heeltoeauto.com
When you finish a total clean and wax and buff- it will look new
You can replace the headlight bulbs now before they wear out, and new bulbs are so much more effective it will feel like a new car about 100$ for HID bulb Phillips 4300K
Install a dashmat carpet cover
These cars are so nice they dont ned much
AHA!
You can paint the inner fenderwell black so it blends in with the tire
secret lowering trick - use paint
Wrong on the headlights
The higher number is NOT brighter , uses a higher lightwave and throws less actual light on the road.
You will find on this forum that answers are very specific and you shoud buy the parts suggested- not what you think may be better, thats why you came here right? for several years of combined knowledge to guide you?
Here is the thread link to MrHeelToe and the Racing Brake rotors with HAwk pads combo sale
https://acurazine.com/forums/showthr...7&page=1&pp=25
Since this car is for your dad, and not you, I would just make sure the car is clean, and up to date on maintenance, and not worry about performance, etc. Things like the tail lights are ok, but a drop, rims, kit, etc would never end up on my fathers car. I am prepared to deal with the consequences/trade offs of those modifications, and unless you know that thats what your father wants, I wouldn't force him to deal with them.
At 75k, I would toss in some redline, or techron fuel system cleaner in the gas tank. After that tank is burned through, I would clean the throttle body, change the plugs, air filter, oil & filter, tranny fluid, coolant, and brake fluid. Check the belts, brakes, cv boots, tires, etc and change whatever is worn out. If those are all good, then call it a day.
After those things, the car should be in tip top shape. A full detail in and out should have it looking in as good a shape as it is mechanically.
Looks nicer to who??????
Are you not inside the vehicle while driving?
Or do you mean the light color on the pavement
