What is this?... pic inside...
Old Jan 30, 2005 | 11:46 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
Hey everybody.. I need to move these two "black boxes" (for stereo purposes) and I'm curious first off what are they?...
I'm planning on disconnecting the battery, and extending the wires going to each of these "boxes" then place them somewhere else...probably just off to the side..
By the way this picture is taken from the trunk looking up at where the stock sub should be, my sub is replaced with black cloth material (if you take out the sub and don't do this you get a circle waffle pattern on the rear windshield when you push the brakes, lol).. The "black boxes" are on the passenger's side of the trunk.
Any advice? anything I should keep in mind when remounting them? if they are both for the stereo (not sure, one may be for the rear brak lights..) I don't even need them, I'm replacing the whole stereo, wires and everything ...
Thanks in Advance for any advice..
Old Jan 30, 2005 | 01:15 PM
1nePhatTL's Avatar
i believe that is our amp. not too sure.q
Old Jan 30, 2005 | 01:17 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Post
This is what I read here
Hope this helps
5. Factory sub/amp info
A common (L+R) signal is sent from the headunit to the EQ. The EQ amplifies this signal
and sends it to the sub amp mounted behind the rear seatback, passenger side. The
black box you see under the rear deck by the subwoofer is a passive crossover, not the
amp. (You can replace everything else and still use the factory sub if you provide
ground, power, and mono preamp to the Bose EQ).
Old Jan 30, 2005 | 01:32 PM
ou sig's Avatar
Boomer SOONER
the one toward the center is for the seatbelt gears and stuff, so I dont think that one is going to move.
Old Jan 30, 2005 | 01:34 PM
NSXNEXT's Avatar
Yup as ou sig posted, I am almost 100% sure that the center one is for the middle seat belt retractor.
Old Jan 30, 2005 | 03:25 PM
Comet2404's Avatar
Flyin' and Drivin'
Yep!! Thats what it is alright!
Old Jan 30, 2005 | 03:55 PM
AustNMike's Avatar
Hmm...Is that right??
ahh...who need's a middle seat belt retractor anyway.....remove it if you have to...
Old Jan 30, 2005 | 07:06 PM
njzprettyboy's Avatar
i took mine out...
Old Jan 30, 2005 | 07:38 PM
Darkshear's Avatar
l33t
Yep seatbelt in the center, the other is for the radio antenna built in to the rear windshield.
Old Jan 30, 2005 | 07:58 PM
ndawood's Avatar
Resident Troll.
when you going to have all this work done Pat?
I am going to be in TO sometime mid-feb. hopefully I can see the finished product!!!!!!
Old Jan 30, 2005 | 08:12 PM
The whole trunk will be brushed stainless steel when I'm done... I should have it installed when you get here... I'm mounting the amps and the sub boxes tomorrow. You'll be able to hear it..I don't think I'll have all the custom work done though... "will it ever be done"
Old Jan 30, 2005 | 08:26 PM
derrick's Avatar
Patrick,
You're gonna dynamat it, right?
Old Jan 30, 2005 | 08:53 PM
Originally Posted by derrick
Patrick,
Yeah I think I'm going to pick up "Brown-Bread" which is basically the same as dynamat but not "priced for audio use" . You can still get it in large ammounts at low prices... @cur@-tl and I are going to split a large ammount of it an do our entire cars.. roof, trunk, floors, firewall, doors, etc.... the car will sound so solid!!
If you're interested in getting in on some I'll keep you posted... I'm still looking at sizes and prices
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
