What is PCM/Fuel Pressure Regulator?
Stock TL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I did my searches in this forum for Fuel Presure and it didn't answer my question.
What is PCM/Fuel Pressure Regulator? This is listed in ALLDATA "03-017 MAY 03 Campaign - PCM/Fuel Pressure Regulator Replacement "
Google searches says it "A fuel pressure regulator is a small device with a diaphragm inside that maintains a constant pressure (or tries to) regardless of the rate of flow. Basically you can put any fuel pressure in, and get a constant "set" pressure out - however much the input pressure might vary. "
and it "simply returns the excess fuel at low pressure back to the tank via a second fuel pipe. "
So with that recall, will it improve MPG?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
xsilverhawkx
09-28-2015 06:51 PM
