what other mounts are there beside motor mounts that might need fixed here?
When the 99 automatic tl is in park and put into drive it makes a loud noise and the engine seems to drop or move in a vertical type of movement not much but enough it make a funny noise, had it looked at and changed one of the mounts but changed nothing and was a waiste of money
which mount was changed--dealer part or what?
front mount-~ $120-150 part, behind radiator- is most common failure.
its fluid filled and some years are vacuum boosted
when its failure not discovered for a long time, the side mount (actual front of engine) fails from taking the extra load- that ones a basic $75 rubber mount
past those common failures- the rear engine mount- also fluid filled like front,
and 2 trans mounts,,rarely fail
engine movement is usually broken mount
the reverse thunk when cold- wait 2 minutes as said before (trick learned from local acura head tech) and seen on here~
and stay off the trans fluid thickener additives!!
There are 5 total mounts for the motor and trans. If more than one are bad replacing 1 isnt going to fix it.
