What mods give you more torque?
mr tl, I was thinking about an exhaust but I think I will go crazy with the noise. I am just like that. How about an intake? My friend got an intake on a civic and it is quiet until 3500 rpm's. Thats all I need. He claims it gave him more torque. Maybe its just all in his head.
Rosh
Rosh
my intake (Xephyr) it extremely quiet until right around 4500 rpm's and even then it's not really that loud. I also have Headers/Exhaust too.
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank> </A>
for some reason i thought you said low end torque
pretty much any performance mod will help torque
an intake will drop your torque by a few pounds around 2500-3000 rpm, but will show substantially increased torque from 4500rpm and up
I didn't notice any gain from my pulleys till the High RPM range......
Comptech exhaust
AEM power pulleys
NSX4dr 3" custom intake
Blitz H/P radiator cap
Ground Control coilovers
Wings West front air dam
19" Chrome Enkei Aegis (coming)
235/35/19 Toyo Proxes FZ4 (coming)
Plastic on grill color matched
Razo shift knob
153mph Top Speed
194.8hp @ the wheels w/o pulleys or cap
Comptech exhaust
AEM power pulleys
Razo shift knob
153mph Top Speed
its true that exhaust helps in high end with the hp but tq is definately lost in the low end keep that in mind
black tl: at least we have a thing or 2 in common looking for low/mid end torque...thas all i need, i dont speed so i dont need the highs
imma invest me a jacobs or msd ignitions
for the jacobs: http://www.jacobselectronics.com/pro...gypaks/dis.htm
and the msd: http://www.turboimports.com/msddis4chani.html
(D.I.S. for the ppl that dont know)its not goin to turn the car into a rocket but it should make a diffrence and i mean a good diffrence.
I believe an intake box (not OEM) will increase low end torque. Usually an open intake will hurt low end (without other mods)while the intake box can store up some air for instance response. At high rpm, it functions just like an open intake for easy breathing.
You will more likely lose torque from larger diameter exhaust pipings due to less back pressure.
If you want torque, you should get turbo (forced induction). That will give you gobs of torque (and power).
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
so with exhaust you will lose low-end torque and gain torque in the high-end?
same as HP?
2000 Metalic Silver TL
OEM Bodykit
comptech exhaust
Comptech springs
Comptech Sway bars
AEM Short Ram
DEI impact sensor on factory alarm
Custom mesh grill
Polarg M-12 Side signals
Acura 7-CD changer
all-season mats
clear door guards
Custom front license plate
Bra - XPEL clear bra, that is.
Pikkachu on the back passenger window
Coming soon!
TL-S tails
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by UW TL on June 22, 2001 @ ]</font>
same as HP?
OEM Bodykit
comptech exhaust
Comptech springs
Comptech Sway bars
AEM Short Ram
Custom mesh grill
Acura 7-CD changer
all-season mats
clear door guards
Coming soon!
TL-S tails
To produce more torque, you will need a higher compression ratio. So, the 3.5 upgrade will do it. Or look at the TL-S as an example.
Your next option can be Force Induction. Header will help, and CAI, exthust will make most of the difference at higher rpm. You will typically lose some torque at the lower end.
I say pulley and ligher wheels are the way to go.
V-AFC or a chip
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs/Sway/Headers Polarg m-6.
CL-S
Originally posted by mgothers:
Where do we find a chip though? It seems hard to find one for our car!
Im not sure for the TL but on the CLs's a couple of peole gained about 5lbs torque at low end.
CL-S
CL-S
level 10 torque converter trust me it works
2001 cl type s
voltage blue, comptech headers, 18 inch ssr agle strusse rims,(painted voltage blue and achrome polished lip) custom iceman intake, pioneer avx 7000 tv, playstation 2, slammed on nex suspension, cross drilled rotors, nos fuel pressure regulator, greddy evo exhaust, level ten torque converter,3.5 liter upgrade(mdx crankshaft, mdx rods, shaved heads, port and polish intake manifold, modified dome topped pistons.compression ratio 10.85:1, s-afc vtec controller
2001 cl type s
heres the dyno, before and after v-afc. he already has I/H/E
CL-S
CL-S
http://www.gpvisa.com/TLstuff/Image_Fr.pdf
its in PDF format
CL-S
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by NOVAwhiteTypeS on June 22, 2001 @ ]</font>
its in PDF format
CL-S
low end torque is REDUCED with intakes, headers, exhausts.. they relieve backpressure which is great for high rpm's but it lowers response down low (just look at dyno graphs for modified cars)
-Fiddler
ControlGenie Automation Systems
1998 Accord EX V6 Coupe (HomePage)
lanechanger
10-13-2015 11:56 AM
joflewbyu2
10-08-2015 12:16 PM
