what kind of grease do you use on sway bars
Old 06-10-2002 | 08:05 AM
NighthawkBlack's Avatar
I did my suspension and I pushed down on the rear suspension floating arm parts to get the rear struts in since I couldnt get the tiny control arm off. Now I have an annoying clunking sound from rears when they move the first inch up and down. Wondering if sways got moved or slightly bent. I wanted to grease them to see if noise goes away so what should I use.
Old 06-11-2002 | 07:45 AM
Hey I thought a lot of you had sway bar noises. What did you use to grease them?
Old 06-11-2002 | 08:53 AM
cforez's Avatar
You can use silicone grease.
Old 06-11-2002 | 10:11 AM
NSXNEXT's Avatar
NHB,
Try tightening your end links on the sway bars. It sounds like they are loose.
White lithium grease works really well for lubing the bushings.
"This all weather grease and lubricant is recommended for general metal-to-metal applications. It is compatible with plastics and rubber and doesn’t drip or run on vertical surfaces."
Old 06-11-2002 | 12:33 PM
vperkins2's Avatar
Thumbs up
After I had my Comptech sways installed (and lube was used) I started hearing a squeaking sound whenever I got in or out or went over a speed bump.
Contacted Comptech and was told that they no longer recommend using the lube... instead they recommend using teflon tape. They told me to go to a Home Depot-type store and pick some up. Took the tape to my dealer and they installed it for free. It's been about 4 months and I haven't heard another squeak!
Hope you figure out what's causing your problem.
V.
Old 06-11-2002 | 11:07 PM
Hmm tephlon tape or that white tephlon you use on pipes. What I mean is it doesnt have adhesive right? Anyway I dont know why it started to make noise now except that I used my weight on the suspension arms to push down far enough to get strut in rear without removing that small thin controll arm. Maybe I loosened something.
Old 06-12-2002 | 07:21 AM
NSXNEXT's Avatar
Yeah I think you should retorque all the bolts to make sure they are tight. I think that's your problem.
Old 06-12-2002 | 07:30 AM
I'll see what happens this weekend and post
tsx_boy
12-13-2019 09:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 09:09 AM
Avenger411
10-11-2015 04:53 PM
hashbrown
09-29-2015 01:13 PM
Quick Reply: what kind of grease do you use on sway bars
