what is this hose for? (atf)
Old 07-26-2010, 06:11 PM
13.2@106mph G37 RWD Sedan
kdawg8526's Avatar
Question what is this hose for? (atf)
i finally found where my atf fill bolt is and it looks like there is a hose blocking it going over it. just wondering what i do now can i unhook this. i got scared because i didnt want to end up having fluid everywhere from unhooking it. so i decided to ask u guys
and anyone know what its actually there for?
heres a pic the top of the pic is the front of the car. vvvvv
Old 07-26-2010, 06:16 PM
thewrangler99's Avatar
it's oil jet kit to prevent heat damage to your transmission's gears
Old 07-26-2010, 06:23 PM
kdawg8526's Avatar
can i unhook it to fill the atf?
Old 07-26-2010, 06:26 PM
Always Working In
my.daily'tl''s Avatar
Yes no problem that's how you fill it.
Old 07-26-2010, 06:29 PM
no idea bro! cuz my 99 tl doesn't have one
Old 07-26-2010, 06:34 PM
kdawg8526's Avatar
thanks guys
Old 07-26-2010, 06:59 PM
Always Working In
99s didn't get the recall. Only 00-03s. Different trans.
Old 07-26-2010, 07:23 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
remove the bolt holding the base mount of the oil jet kit -its 10 or 12mm iirc
pull entire unit straight up and out
Use a long necked funnel to add trans fluid--avoids a mess
stay on Honda ATF unless going with a full fluid swap out to another brand like redline
Old 07-26-2010, 07:25 PM
01tl4tl's Avatar
its purpose is to import oil direct to 2nd gear shaft, which has low flow in its design and would break suddenly at 70 mph when overheated
thats the actual recall on the trans- to install that kit
not related directly to our main prob of low cooling to the clutch packs and their wearout
Old 07-26-2010, 08:21 PM
kdawg8526's Avatar
thanks for the clarification Tom
does that mean my tranny has been replaced??
Old 07-26-2010, 09:25 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
No, it means it was brought in for the recall, The racall was for the addition of the oil jet
Old 07-27-2010, 02:34 AM
01tl4tl's Avatar
NO
chances are its an original transmission- or a pre 05 replacement
You can visually confirm by looking at the main trans bolts that go thru its length- bolt heads painted BLUE means factory warranty unit
unpainted- stock
Old 07-27-2010, 02:44 AM
kdawg8526's Avatar
so when doing the 3x3 do i have to go thru the trouble of connecting this hose back again and removing it again everytime when i do my drives between the 3 drains?
Old 07-27-2010, 02:53 AM
YeuEmMaiMai's Avatar
^yes unless you want trans fluid everywhere
Always Working In
Yes. Unless you still have the atf bolt. You only need to make short drive through all the gears between changes.
Old 07-27-2010, 06:59 AM
fsttyms1's Avatar
Yes, removing this is easier than removing the ATF bolt (for the first time) there is nothing to screw up, nothing to realign. Unbolt it pull it straight out and then put it back in and bolt up. Its very easy.
Old 07-27-2010, 10:12 AM
05TSXPAT's Avatar
I just changed my tranny oil and went through 9 Quarts to get it back to a nice red color. I went through the dipstick tube and its easier that removing the oil jet.
Get some plastic tubing that fits OVER the dipstick tube and connect it to a funnel and then hang the funnel on the hood latch. It really does not take that long for each quart to go down. I will post pictures if my explanation is as clear as mud.
Pat
Old 07-27-2010, 04:19 PM
kdawg8526's Avatar
just changed my tranny fluid man that oil jet got annoying to take off every fill i must have burnt my hand 20 times
Old 07-27-2010, 06:14 PM
crazyjkz's Avatar
Originally Posted by 01tl4tl
NO
unpainted- stock
The bolts on my transmission on my 2002 TL 5-speed auto are actually painted GREEN. Does anyone know what this would indicate about my transmission?
Old 07-27-2010, 06:32 PM
01tl4tl's Avatar
they may have changed the color at a certain point in time
when was your trans replaced?
Not sure?- usa residents call acura usa 1-800 382 2238x 5 register as owner and ask about warranty repairs and open recalls
canuks 888-9acura9 for canada acura reg
stock trans has no paint on the bolt heads
exception= certain marks to indicate bolt was torqued
Old 07-27-2010, 07:59 PM
fsttyms1's Avatar
Pat
Yes it does. i could remove the oiljet 4 times before one could get the 3 quarts down the dipstick hole.
Old 07-27-2010, 08:00 PM
fsttyms1's Avatar
Gloves
Old 07-27-2010, 08:03 PM
kdawg8526's Avatar
haha yea thought of that after too. i was just like oh well. and i had lots of towel which helped at times
Old 07-27-2010, 08:04 PM
fsttyms1's Avatar
I actually like this method of changing fluid
http://www.youtube.com/watch?v=MsdPAadc9fY
Old 07-27-2010, 10:21 PM
05TSXPAT's Avatar
In the beginning of your video he puts in the fluid through the dipstick hole using a funnel, not that slow if you ask me. I just couldn't find a funnel long enough so I used a rubber tube to get to it.
And you are right, that is a great way to change the fluid.
-Pat
Old 07-29-2010, 07:08 AM
fsttyms1's Avatar
-Pat
i dont agree with the fluid fill method though. I never used a long funnel. I just got one i could stick in the hole then pored the fluid into it. I never had a problem adding fluid. You could also attach a larger piece of hose (like garden hose) to a funnel and stick it over the funnel and into the fill hole and fill from up high To each their own.
Old 07-29-2010, 09:29 AM
01tl4tl's Avatar
I forgot the TL oil filler is pretty easy to reach and a shorter funnel with larger diameter opening will work fine
practice your pouring technique~
spudweb
05-22-2016 02:39 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
hashbrown
09-29-2015 12:13 PM
kingbharj
09-25-2015 07:25 PM
Quick Reply: what is this hose for? (atf)
