What else is there for suspension?
I installed the sway and strut bars and I am getting the springs and struts soon.
What else can I change to tighten up my suspension?
yea but thats obvious...I need to know about other intergral parts that are not usually discussed. I think I'll take a trip down to the local performance center.
other than springs and shocks the only other things are sways and bushings. a REALLY good pair of shocks that are adjustable are the best
Blown is Best
What type of tires and Rims are you running? If you really want to get serious, go with a good set of coil overs and find a suspension shop to do a corner weight set up. Also add the front and rear camber adjusters to give yourself more flexabilty on suspension set up.
not to mention the fact that ur tires will thank you later
I wanted to get one of the HRE wheels. 18/19 not sure yet. So far I got this....
- Comptech Springs
- Comptech Sways
- Comptech Strut Bar
Need to get the
- Tire/Wheels
- SPC Camber Kit
What comes with the coil overs?
- Comptech Springs
- Comptech Sways
Need to get the
- Tire/Wheels
- SPC Camber Kit
Blown is Best
If you already have comptech Springs, go get yourself a good set of adjustable struts. I personally like the Tokico Illuminas. World of difference and it gives you flexability on how stiff you want to set up your car.
Coilovers are struts with springs that have an adjustable perch. You can raise or lower the car by moving a threaded perch. Most of the people don't set them up properly for handling and use them for looks. Advantage to coilovers is that it gives you a ton of adjustment options if you're willing to spend the time. The threaded perch for most people is just a height adjustment. Good shops can do corner weight adjustments by adjusting the perches. They will stick a scale under each wheel and adjust until each tire has a relatively close weight so all tires apply even pressure. This is standard procedure for the Porche's. You can also vary springs easily and even stack multiple springs on the same stack to give you a progressive setup.
Anything is possible. Depends on how far you want to take it.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
