What do the shops use?
I was wondering, just a random thought... I was hoping of using this for future references when it comes to another future mod on the car. The shops, when they replace your exhaust and headers, the tools they use make those rusted pieces of shit come off easily... Question is, how much ft./lbs. of torque do their air tools put out to make the job so easy?
True, but my neigbor's got tools also.. I wanted to see if their tools would be almost the same as his so that I can use his impact wrench/compressor rather and avoiding a mechanic at all costs... You already know the crap I have to deal with in my current situation
In my experience the pros cut everything off with a torch or power saw. At home I use penetrating oil and a long handle on the sockets, but I still expect many of the nuts to twist off (break off). Strength really isn't an issue.
It depends on the extent of the rust. Many times it's easier to heat up the bolt and impact wrench it. Sometimes it's easier to break it off, then replace it with a new one.
If unsure - get a pro to do it. You'll spend all day under the car (perhaps unsucessfully) for a job they could do in a half hour.
Former Sponsor
Up in the Northeast impact tools are really enough to get most bolts out. The cars though that have been absolutely beat on, barely maintained, sat with the salt from the roads, etc.. those bolts you take a nice torch too. And I'm not talking those little torches that cost $20 from Home Depot. I, myself, like to use a oxy-acetylene torch... that bolt looks like lava in about 20 seconds.
Originally Posted by fla-tls
Up north - the torch is your friend. Down south - the regular set of impact tools do just fine.
No rust under the vehicle down here!
Originally Posted by MikePA
500 ft lbs and more and you also need the right size air compressor to run the tool at its rated capacity. When I tried to install my Comptech Axlebacks, I used penetrating oil and my 500 ft lb impact wrench (IR). After an hour of trying, I went to Midas. In less than an hour, they had the Comptechs installed. They used an OA torch to burn the rusted bolts out.
Don't waste your money on massive impact tools, for the occasional exhaust job, a sawzall (reciprocating saw) will make short work of cutting the system into small pieces, no need to grunt with the rusted clamps & flanges.
The only fasteners's you'll need to take care with are the studs on the exhaust manifolds. Penetrating oil the night before & a torch if that doesn't get it. A broken stud can be an absolute nightmare to replace.
Originally Posted by optomos
Just rent a oxy-acetylene torch for removing anything from cat back. The rest will only require basic air tools/tools.
Also, doens't the cost depend on the size of the tanks also?
Wow.. this is starting to be come an informative thread.. I'm liking this
emailnatec
29
Sep 28, 2018 04:27 PM
DerrickW
Nov 15, 2015 05:52 PM
