what are the casues for terrible gas milage?
#41
TL-S driver
I have an 02 TL-S also with 99,200 miles and I get 300 miles a tank. If I don't go out on the weekend I fill up for work once every 2 weeks. My parents MDX is having some major gas mileage problems and we changed the plugs, air filter, seafoamed into fuel, checked tires and my mom drives it so I know she's driving slow. Any other idea's? O2 sensor?
#42
I tried Acetone on my car and it work & improve extra average 3 MPG. Before I only got 18~19 MPG with 50-50% freeway & local. And I only put the regular GAS. I have tried the premium gas but it gave me worse than regular gas on MPG. I don't know why. When I start tried it really improve engine at ideling and running, it a lot quiet than before.
#43
The Talk of New York
Does anybody know if the NGK Iridum IX spark plugs found in this auction will fit my 02 TL-S?
http://cgi.ebay.com/ebaymotors/99-03...spagenameZWDVW
The reason I'm asking is because the description doesn't mention anything about the Type S model, so I just wanted to confirm with you guys if these are the correct plugs for my car.
#48
ZK.TBK.SCR.BIA.X408
tires being under inflated and having hella shiet in the trunk is americas number one reason for worse gas mileage than expected..try those along with erthang else
#50
"gas mileage"
Originally Posted by Wildwing
Well, 10 MPG is a car in need of service, pure and simple. My 3G TL gets 33 on the highway and in the 20s with a combination of city and highway.
#51
Will having your car lowered affect Gas mileage...? I have Tein SS installed...also I have the 3rd gen Wheels on...tires are pretty low... I'm going to inflate them to the proper psi today.
FYI
I just filled up again this weekend and got 243 Miles on the trip.
Divided by
15gallons= 16MPG,
14gallons=17MPG.
I use those figures cuz I every time I fill up thats how much gas I top off @.
HELP!
P.S.
I'm going to do my EGR/intake/TB cleaning sometime next month.
FYI
Divided by
15gallons= 16MPG,
14gallons=17MPG.
HELP!
P.S.
#52
FYI
Divided by
15gallons= 16MPG,
14gallons=17MPG.
HELP!
P.S.
FYI
Divided by
15gallons= 16MPG,
14gallons=17MPG.
HELP!
P.S.
#53
Kilos of yayo in
I get pretty bad mileage at 15-16 mpg on average. If I drive like a grandma I get 17 at best. I did plugs about 3k miles ago. I seafoam like crazy. Check my tires constantly. Have CAI and headers. I used to have a pretty heavy sub and box in trunk. Took that out same gas mileage. Have not tried cleaning EGR port and throttle body that may be the problem. I never remember getting that great of gas mileage ever in this car though.
#54
Originally Posted by 100degrees
3g rims are heavier and wider than 2g 16's. I used to run the same setup and noticed a difference of 3-4mpg per fillup (12 gallons) vs the stock rims.
Thanks for your insight! More of a reason to get Type-S Wheels...
<<shopping for CL-S wheels asap>>
#55
If the majority of your driving is city or your in stop and go traffic your not going to improve much if any with different rims, also if your drives are short drives that will hurt mileage as well. If thats all your getting all hwy then there is something wrong. Having sorrect psi (32 and ABOVE) will help out. Changing driving style is another key
#56
Something is missing...my
Also, I run 3gTL rims and get 22 - 25 combined depending on how early i roll out of bed!
Driving style is key. I have not weighed the rims but they are indeed larger, tires are more likely a bigger impact. 1st as fsttyms1 stated, pressure; 2nd size = weight. I have 235/45s on mine. you have a ground effects kit and are lowered, which also should reduce the drag from the tires extending farther out, I don't. I have a two piece brake rotor which weighs less.
Just a little more info for the 3G setup for you to take into consideration.
#58
Originally Posted by Bkz3.2tL
do changin ya spark plugs help with the gas milage any?
Juss sumthing I heard. .
#60
Culprit?
I think I found the culprit! I was doing some spring cleaning and when I got to the engine compartment...My comptech elbow was disconnected from the air filter box. Looks like the glue was old or something and it was disconnected. I used electrical tape and put it back on w/ a snug fit... then taped the outside of that... I'll take some pics and post this weekend. Filled up a the tank....1 can of seafoam in my tank (prior to fill up). Hopefully that'll help w/ my mileage
BTW....175 Miles on the Trip
When I filled up I topped off @ 14.something gallons.
Always have used premium.
So thats like 13/14 MPG
#61
I used to get like 300 on a tank of gas and mine has dropped to like 200. With gas prices going up I can't afford that kind of drop do you have any suggestions on why this could be happening or how to fix it. PLEASE HELP
