What Are The Best Rotors? (Mine are Warped I Think)
My steering wheel shakes when braking at high speeds... I also noticed rust on the rotors after I bought the car about 2 yrs ago... It doesn't bother me that much, but I know I'll have to do something about it sooner or later.
When I'm ready should I get new rotors or just have them resurfaced?
If I get new rotors... Which one's are the most durable/best or best bang for the buck at least?
I have seen cross drilled/ slotted but I don't know any thing about them. Do they make your brake pad wear faster or slower? Do they cause more of that brake dust that is a pain in the arse to get off my white TL? Should I get just slotted or just drilled or both and are they durable as the stock rotors?
I heard I should stick with the OEM brake pads? Even if I get slotted/drilled?
I have no clue on this plz help...
I guess just tell me what to get on a silver platter
I also read on the forum not to wash your car after driving your rotors hot.
I am still running on my stock rotors 00' TL-P with 62k miles. If I had to change them out I think I'd go with the rotora or irotor rotors (almost everyone talks about rotora rotors on this forum). I heard cross drilled rotors are the easiest to crack and is mainly used for track purposes. I'd stick with a regular or slotted rotors only. As for pads, I'd go with EBC greenstuff, oem, hawks, or satisfied pro ceramics. I'd rather pay for a new rotor than to resurface unless it doesn't cost too much. That's just my opinion.
@ slide or die @
you might wanna browse thru this:
https://acurazine.com/forums/showthread.php?t=108051
but yeah, dont have the dealer charge $500 for new rotors, get aftermarket performance rotors for much less. easy installation as well.
I'm interested in brembo or rotora, even though i heard the pads are what make our acura rotors warp. I really want quiet pads, cant stand that squeaky sound. Any recommendations on quiet pads like oem but hopefully better.
I'm Cool
After Reading The Other Thread
Probably expensive, but it seems that the best rotors would be dimple+slotted and have a cadmium or zinc plating? And the pads should be based on how you drive...
I do drive fairly fast... I avg 45-60mph on regular streets and around 80mph on the highway... I'm being honest
__________________________________________________ _______________
I actually got pulled over.. The cop was like, " Did you notice you were going an amazing 73 in a 35?". It was 5:30am and I just took my woman to the airport... The only people on that road were me and the cop that instant onned me...
I just laughed and said... You caught me trying to have some fun... Then I called my lawyer when I woke up arrrgh!
Anyway... What pads should I use? and do I really need dimpled or should I just stick with slotted only? I don't want to eat pads and it's not like I'm a racecar driver.
I also hate that rust & dust crap... is there a spray or just to buy some zinc plated rotors?
Originally Posted by mrsteve
Bad guess, they warp too.
Go with Rotora
Go with Rotora
How about these? Anyone ever tried or heard of cryogenic treated metal?
http://www.tirerack.com/brakes/brake...-Treated+Rotor
Received 1,080 Likes
A few people have the Poweslot rotors and seem happy with them.
TL Brakes Issue
Originally Posted by Doc Holliday
I want the setup that lasts the longest with minimal amounts of brake dust.
Brembo Brakes
So, of these....
What's the best bang for the bucko?
Durable rotors and durable brakes that don't make lots of dust and last.
OMG..what the hell are you going to use these for?
Originally Posted by 2003 Acura TLS260-Silver
Check out Brembo brakes at www.brembo.com for more info. Brembos are a very reputable name.
Originally Posted by MikePA
Is there a problem/defect with the stock rotors that is causing them to warp?
I also know that if I'm going to pay for new rotors... As a consumer, I work hard for my money so I want good one's for good price.
-THE OPTIMAL SETUP-
All I know is that my steering wheel shakes like a SOB when I'm braking down from around 65mph+...
It maybe that ppl aren't installing them properly?
I got my brake job done at the dealer and everything is really good with my brakes with still the OEN rotors that it came with.
Former Sponsor
Originally Posted by NSXNEXT
Rotora slotted with Satisfied Pro Ceramic pads....
and Goodridge SS lines for good measure.
Having them installed tomorrow.
I have the same set up on my CLS, instead of the satisfied pads i have the metal master ones, i'd say its the best set up i.e. right behind the bbk.
I have close to 7k miles on my Rotora/Axis Ultimates/SS lines and the braking is a night and day difference over the OEM equipment. I'm going to try a different pad next time though. The Axis Ultimates are loud and very dusty.
Yeah !
Originally Posted by adyskrilla
Since most people are recommending Rotora's and EBC Greenstuff's, can anyone recommend a site that has a great deal on the combo?
:gheywave:
WhizzBomb
Good luck,
Joe
El Presidente
My setup consits of iRotors in the front and EBC Greenstuff Pads. They are a lil noisy due to the rotors being crossdrilled and slotted, but i think they are well worth it.
WHAT?! NO MORE EBC FROM TIRERACK?!
