wet sand and buff
wet sand and buff
i got a question for everyone.. one of my friends just inherited an old acura legend and the paint is deoxidised then a mother. were going to attempt to prep it for paint ourselfs but need some help . yes we are rookies ..
well what i need to know is how do i prep the it?? i know there has to be some DIY on here somewhere but i couldnt find anything..
so if anyone knows what tools too use, how to prep the current coats... etc i would love you forever.. thanks
check out the color sanding video and the power polishing video.
http://www.meguiars.com/video/
if you have any more questions come back and ask.
1) Warm and dry conditions are ideal for spray painting, as aerosols don't always work best in the damp and colder temperatures hinder drying time. If it's not warm and dry outside, work in a well-ventilated garage. Wear overalls or old clothes - goggles and a mask will keep stray droplets of paint away from your eyes, nose and mouth.
2) To prepare for spraying, use aluminium oxide abrasive paper (graded at 80grit) and rub the surface to be painted down to bare metal. Apply a rust treatment product if required, following the manufacturer's instructions and allowing it to dry fully.
3) The area to be painted should now be clean and dry - any traces of dirt or wax can be removed using cellulose thinners. Mask off any areas not being painted using masking tape and paper (to avoid hard edges, increase the area to be painted by moving the masking tape back gradually as you apply each coat of paint).
4) Holding the spray can approximately 25cm away from the surface to be painted, apply a number of coats of primer at 15-minute intervals until the area is evenly covered. Go an inch over the original layer of paint to help it blend in (to create an even softer edge, peel the masking tape back from the surface slightly). When spraying, use a smooth movement from side to side. It is best to apply several light layers of paint, as applying too much paint in one go can create sags and runs.
5) Allow at least 24 hours for the primer to dry thoroughly, then rub down with 120grit wet and dry paper until smooth. Clean the area with warm, soapy water, rinse, then dry fully.
Hope this helps.
Hope this helps.
if the paint itself isnt peeling you can simply wetsand with 600 grit (after you cleand it good and degrease) then like the above said start layng on paint (i wouldnt be hoping for alot out of a spray can though on a large surface) after you get all your painting done and it has cured then rewetsand with 1500-2000 grit and buff and polish
also if your doing the same color and there isnt any body work done there is no need for primer
Moderator Alumnus
Hope it all goes well. If you need more info I suggest you post in Wash & Wax forum.
Oakes
Wash & Wax
10-12-2015 11:17 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
