Waxing tips
Old Jul 2, 2001 | 03:31 PM
Sleeper_RENAMED's Avatar
Waxing tips
Do you need to strip the old wax off everytime you put a new coat of wax on?
Old Jul 2, 2001 | 04:18 PM
CBS
Lately I haven't because my car is only 4 months old. I usually wax my car once a month anyway. After each wash, I use a QD(Quick Detailer) that contains carnuba to preserve the wax that is on the car because wax usually starts to breakdown after 180 degrees. Of course, it all depends on your car color too. I have a black car and it does not take long so that is why I use a QD. As far as taking off old wax, it is up to you. I will strip the wax on my car after winter and in the middle of the summer because of contaminants and so forth. Put it this way, after you wash your car, if it feels smooth to the touch, then go right to a polish then wax. If not, then you will need a gentle paint cleanser. Hopes this helps!!
Old Jul 3, 2001 | 02:25 AM
jimster716's Avatar
Wink
it should be okay to wax without removing your old wax but make sure you remove all wax periodically.. but i prefer to do an exterior detail every 6 months with 4 steps.
1. i wash the car
2. i strip the old wax with a stripper (chemical not female...i wish)
3. i apply a polish/swirl remover
4. then i do a final wax
if your finish isn't smooth, use a clay bar with lubricant (you can find it at any wash section of an auto parts store) to remove oxidation. but i would only do this evey couple of years since the clay bar make actually remove more than oxidation. do it between steps 2 &3.
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
ivan06106
Sep 26, 2015 04:38 PM
