wats the diff between Tokico blue and illumina?
hey guys,
im gona get the comptech springs and i need shocks to match it...
now i heard about tokico blue and illumina, but just dont know what the difference is... can anyone help me??
thanxx
thanxx
i forgot to mention... i have no idea wat any of those numbers mean 1-5... all i know is that those are two diff types of struts, have no idea about anyting else... i apologize for not stating before, but can you explain that a lil more in detail about the numbers and wat you suggest if i am just gona be driving in 'cruising' mode... i dont race or anyting i just want the car to look good...
thank you
thank you
Blown is Best
Originally Posted by SilverIce2000
wat is the ideal cruising ride setting? cuz if the blue is 2.5 to 3 and 3 is ideal there is no reason to get the adjustable as i do not race.. wat do you think?
TLStar
Blue
Since ur here in NYC, u might be better off getting the blue, not only do u not have to bother adjusting them all the time, the blues are fine the way they are and pretty good. I have them on my '97 Civic and they're better then the KYB garbage I had before them.
a bit confused... so the levels for tokico's are 1-5 and ur saying the blue is about 3... soo 3 is good for cruising??? and the illumina's which allows 1-5 is good for cruising and racing right???
thanxx guys
thanxx guys
thanxx guys
thanxx guys
Originally Posted by Allout
I think the Blues are closer to 1.5 to 2. If you do not race or drive your car aggressively, blues will probably work for you.
why do you have camber kits all around?
did you notice an imporvement in ride quality after you installed them?.
Blown is Best
Originally Posted by Joseph_99TL
allout?.
I just like to do things right and not just at an acceptable level so I don't mind spending the money to do so. The front and rear kits are only worth around $250 and I installed myself. Spend $900 on a set of tires and the payback on additional tire life calculates to a pretty quick payback while getting the most handling out of the car.
I used the Tokico Blues on my 300ZX for years before I switched them to Illuminas. They are a great all around strut and recommend them if you don't need the flexibility of different suspension tuning.
Thanks for asking - sorry for the long winded explanation
The numbers adjust the stiffness of dampening and rebound.
Blue's will be more than sufficient for 80% of people but I actually run mine set to 1 in the front and 3 in the back. I find this to be the best combination of reducing understeer and for a balance of comfort and performance.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
