Warped rotors?!?!
Old Oct 4, 2001 | 12:49 AM
nycvr6's Avatar
Warped rotors?!?!
Anyone experience this on their type s? My car shakes under hard braking, i know a rotor is warped because ive delt with this before on other acuras...The car only has 6030 miles on it..
Old Oct 4, 2001 | 01:34 AM
LoveSick's Avatar
If you want to prevent them, here are some ways:
When you are going to some hard brakings, down shift so you take less pressure from the rotor.
Do not drag the brakes when trying to stop, tap on them lightly and give your car more distance to stop.
Do not wet the rotor when they are still hot
When the rotors are rusted from washing the wheels, slowly and lightly tap on the brake at a low speed to remove the rust.
After some hard brakings, try to avoid contact between rotors and pads. If you are stopping your car, stick it in neutral and pull the ebrake. This way, your rotors will cool a little faster.
Hard brakings will definetly warp your rotor, don't do it too often.
Old Oct 4, 2001 | 09:47 AM
rockinTLS's Avatar
I wish we could "pull" the ebrake. No such luck on the TL, yet.
Old Oct 4, 2001 | 09:52 AM
Road Rage's Avatar
Not a Blowhole
Make sure the lug nuts are torqued to spec. Too tight and the lugs will pull the rotor hat, warping the rotor.
Old Oct 4, 2001 | 03:38 PM
2K2SilverTL-S's Avatar
AZ O.G NoOldManVetteOwner
I had the same problem. I had my rotors resurfaced and my front brake pads changed at 5000 miles! Go to your Acura dealer immediately. Some TL-S's have that problem and IT IS COVERED UNDER WARANTY!
Old Oct 4, 2001 | 08:05 PM
LoveSick's Avatar
BEWARE!!!
While your car might have a 3 years warranty, but the brakes are only covered for ONE YEAR!
If you have a problem, goto get it fixed under warranty as soon as possible!
Old Oct 4, 2001 | 11:29 PM
RedLined's Avatar
Re: BEWARE!!!
What?! The rotors aren't covered under the bumper-to-bumper warranty? You've got to be kidding. I can understand the pads but not the rotors.
Old Oct 5, 2001 | 04:38 PM
ASU - TLS's Avatar
what about that so-called "bumper-to-bumber" warranty?
Old Oct 5, 2001 | 05:41 PM
LoveSick's Avatar
Unless my dealer was ripping me off, I believe there should be no bumper to bumper warranty for anything that will be worn.....
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
