VSA engages for no reason
Since today my VSA has been acting very strange. The system goes off whenever I accelerate from a dead stop (ie: stop sign, signal light). It goes on for about 2-3 seconds then stops and everything goes back to normal. It happens during ALL kinds of acceleration. The other scary thing is it also goes of when im braking, when I brake to a dead stop at about 2-3mph the vsa engages until the speed drops down to 0. This all happens during ALL kinds of braking.
The system does the auto check upon start up like normal, and if I turn off the VSA it doesn't duplicate the symptoms im having as stated above. I don't know if anyone ever had this problem before but would like to know whats going on with my VSA system.
your likely suspect is the wheel speed sensor- that toothed ring on the axles -behind brake backing plate- thats it- with a sensor and lead wire thats easily damaged
or corroded inside the wire and sending bad signal
A brake specialty shop will have the special code scanner to confirm problem
or you can crawl and look to see whats going on where
or try a parts store and see if regular scanner will come up with a code
for now turn vsa off
Ok so I have a similiar problem. My VSA and TCS lights are on. I replaced a wheel speed sensor as it was junk, and had my mechanic read the codes. He said nothing is coming up for these lights. Anyone have an idea of what might be putting these lights on?
if 1 was junk- its opposite side may be too- or the other end of the car
if thats not the problem, you may need a specialty brake shop or acura
there is a special code reader for abs - that normal scanner wont get and
those places will own the right one
call `acura care` and report the problem- they will tell you to take it to the dealer--but at least get a report started
1-800 382 2238 x5
1-800 382 2238 x5
did you try a system reset by pulling the CLOCK fuse on passenger end of dash?
put it back after a minute, the car goes into forced relearn
same result as removing battery neg cable, except this way you dont have to enter the radio security code
I had to brake hard for a light change today, once I stopped my VSA light and the red Brake light right next to VSA light illuminated and stayed illuminated. I turned my car off and then back on, and both lights are still illuminated. What do I do!?
Ok here's an update I cant get any DTC's off the system!!!!!! I get a random ! ABS VSA lights on the dash for about 20 min then goes away by itself while driving. VSA still engages for No reason... WTF do I do? It feels as if the rotor is turning inside but not the tire!!
1-800 382 2238 x5
1-800 382 2238 x5
The VSA button only pushes in correct? It doesn't click for anyone correct.
Jamus22
06-11-2023 10:08 AM
MetalGearTypeS
08-29-2016 08:28 PM
