Vibration from 45++
Old Mar 24, 2010 | 09:04 PM
ANC297's Avatar
Bonki' Ehrite!
Vibration from 45++
As soon as I hit 40-45 mph, I get a vibration, you can feel it in the steering wheel and a little bit throughout the car..like the ride is a lil disturbed...
-It gets to its worst at around 65ish mph, and kinda came out of nowhere.
-I am 99% sure its not a bent wheel, because I havent ever hit any curbs, potholes, etc.
I have searched a lot and narrowed it down, sort of...
My ideas on what the issue can be:
-Off balance/alignment
-Warped rotors...There has been brake vibration for about a month now, but starting yesterday I have a vibration both on and off the brakes.
-Endlinks, ball joint, etc...Something in the suspension.
-Thats really all I can think of, I do know that my Front motor mount is shot, could that be a source of the issue?
Any and all help is greatly appreciated.
Old Mar 24, 2010 | 09:08 PM
phee's Avatar
I got the Shifts
does it happen wen you are not accelerating?
Old Mar 24, 2010 | 09:14 PM
ANC297's Avatar
Bonki' Ehrite!
Like just coasting? I didnt really pay attention to that.
What effect would acceleration have?
Old Mar 24, 2010 | 09:17 PM
hANDYcaptd's Avatar
It's the Halladay season!
Accelerating vibration is usually the axle.
This sounds like a bad wheel bearing. Jack up the wheels and check for play in them.
Old Mar 24, 2010 | 09:24 PM
ANC297's Avatar
Bonki' Ehrite!
I just looked over the DIY and Kris's recent thread on changing his wheel bearings and noise seems to be the indicator of shot bearings....I have no noise.
And is the bearing race just a cover, or what?
Old Mar 24, 2010 | 09:37 PM
JDTL-S2002's Avatar
i had a similar problem. got my front tires rebalanced today actually and rides like butter again.
Old Mar 24, 2010 | 10:29 PM
ANC297's Avatar
Bonki' Ehrite!
Hmm..
Old Mar 24, 2010 | 10:40 PM
99AcuraTL03's Avatar
is too sexy for his shirt
i had the same problem in my 01 tl-p... to solve the problem i bought a 03 tl-s
Old Mar 24, 2010 | 11:00 PM
TLin401's Avatar
'13 Hyundai Sonata
If it was your ball joints, you would hear a clunk every time you went over ANYTHING.
If your rotors were warped, then you would only feel it when you slow down. Your pedal would vibrate and your steering wheel would shake.
If it was the alignment, then you would hear things rubbing. Unbalanced tires would cause the tires to hum and cause uneven wear.
This sounds like an axle issue to me.
Old Mar 24, 2010 | 11:09 PM
hANDYcaptd's Avatar
Bearing can cause vibrations too. Try and take notice if it's happening when you accelerate. Could be axles.
Old Mar 24, 2010 | 11:40 PM
ANC297's Avatar
Bonki' Ehrite!
I'll see if it occurs under acceleration tomorrow.
Now is it safe to say that since the steering wheel is vibrating, that the issue is in the front?
Also, would the axle be reacting like this if it was bent, or is it just wear and tear?
There is NO noise. Only vibrations.
Old Mar 25, 2010 | 12:27 AM
fobstylez's Avatar
I have the same issue, I'm not really sure what it is. I had the axle checked at a speciality shop and no go. They found out my mounts were blown so I replaced two of them. I havent had a chance to check out my tranny mount, which I'm hoping it might be it. I switched to my stock rims and it helps out a lot but you can still till its there. I'm going to swap out the suspension to stock here sometime soon, some guys who experience vibrations said it went away when they raised the car up. Going to take my car into the dealership soon for a timing belt, I might just have them figure it out if I cant. Are you lowered?
Old Mar 25, 2010 | 12:31 PM
ANC297's Avatar
Bonki' Ehrite!
Not yet lowered. I know for sure my front motor mount is a goner....
Old Mar 25, 2010 | 06:44 PM
01tl4tl's Avatar
if you know the vital mount that holds many things together is shot- that will allow axles to move as trans moves...stop searching until thats resolved
Plus some years have a vac boosted mount which causes rough running when mount blows
If the fluid is leaking out--replace it now
then test drive and say-hmm fix known problem first.....I seeeeee
Old Mar 25, 2010 | 07:14 PM
ANC297's Avatar
Bonki' Ehrite!
Where would I see fluid?
Old Mar 26, 2010 | 02:37 PM
ANC297's Avatar
Bonki' Ehrite!
It does still vibrate when I get off the gas, but it gets a more definitive an aggressive vibration while under acceleration.
Old Mar 27, 2010 | 01:18 AM
01tl4tl's Avatar
put the car on ramps
look UP at the front motor mount from below and a thin trail of dust (leaking a long time) or fresh oil may be coming from it
Or you may see a few, 2-3 drops, on the ground just behind the radiator
Very strange fluid so you know its not engine oil or trans fluid
Old Mar 28, 2010 | 01:47 PM
Aznryda43's Avatar
2nd gens rock!
i changed my motormounts and tranny mounts got most of it but you can still feel it there. i still have that vibration when hitting 45.
Old Mar 28, 2010 | 06:59 PM
Madchiln's Avatar
yea man acceleration is def. axles i just had mine changed, dam dealer had to charge me an arm and a leg but its all good now. Did you check your lugs to see if they were on tight? i had a friend who had 2 loose ones once had similar problems..
Old Mar 28, 2010 | 09:16 PM
mmendelzon's Avatar
same problem speeding up and slowing down
shop told me my axle is slightly bent and the car pulls to the right
how much is an esitmate range for repair???
Old Mar 28, 2010 | 09:38 PM
ANC297's Avatar
Bonki' Ehrite!
From Advanced Auto, axles for out car are 60-80 bucks a piece. So it depends on if you do it yourself, or bring it to a shop you would have to add labor.
Old Mar 29, 2010 | 03:41 PM
mmendelzon's Avatar
what about framework i hit a real bad salt pile durig the snowstorm in baltimore adn i believe i heard a mecahnic say i needed framework done? 500$? how does the frame effect my vibration i though only the axle effected the wheels
Old Mar 29, 2010 | 04:18 PM
fobstylez's Avatar
if your frame is off then everything else is off, so yes, frame would effect your car's alignment and vibration should occur.
Old Mar 29, 2010 | 10:48 PM
ANC297's Avatar
Bonki' Ehrite!
^.What he said.
Are salt piles really that serious that it could bend the frame though? I've lived in So.Fla all my life, so I really don't know that much about it.
Old Mar 30, 2010 | 12:59 AM
01tl4tl's Avatar
could probably bend a control arm- that would screw everything up too
Get a real estimate from another shop and fix the problem
NAPA has brand new axle assemblies for about 100 bucks
Old Mar 30, 2010 | 11:47 AM
ANC297's Avatar
Bonki' Ehrite!
I noticed last night on the freeway, the vibration stops once you pass 65 mph. I took it up to 95 with no vibration. Its only in the 45-65 mph window.
Old Apr 1, 2010 | 01:31 AM
tri2tun's Avatar
Would it have to do with the transmission? Maybe something wrong with 4th gear? Since it stops when you're in 5th gear (>45mph)
Old Apr 2, 2010 | 01:47 PM
fobstylez's Avatar
yeah mine does the samething, once I hit my avg on i-5 about 80mph, its fine. So I called this shop I was referred to, an acura/honda specialist for a 105k change ($567 cheeeeap), i asked hiim about the shaking and he told me chances are its my axles. I think I'm going to attempt to replace my axles. il'l let you know how that goes, because I checked a lot of things and they look ok.
Old Apr 2, 2010 | 07:54 PM
ANC297's Avatar
Bonki' Ehrite!
Keep me posted!
Old Apr 2, 2010 | 07:55 PM
XxXboboXxX's Avatar
Told Ya'LL...DYNASTY !!
Yea I'm interested in this as well, my car does the same thing... Switched out the wheel bearing and a couple suspensio.n components as well and it's still there.. All I have left. To check is axles.. Going to get alignment and balance tomorrow but I'm pretty sure it's not that cause the vibration is there with both my stock rims and aftermarket 19s... Keep us update when you switch out the axles fob !!
Old Apr 2, 2010 | 08:50 PM
RalphiieP's Avatar
B A N N E D
i had the same exact problem, balance and you should be good but than again i didnt read any of your other posts, just ur tittle
Old Apr 2, 2010 | 09:07 PM
Sust Man's Avatar
I had a similar problem. I had the motor mounts fixed and the problem decreased by about 60%. Next I replaced the upper ball joint (it had play in it) and the problem disappeared completely.
Previously I had another TL with a similar problem at low speeds. Believe it or not, it was 100% tires. The steering wheel even wobbled. New tires, no prob. Rotate your tires front to back to help rule out a tire or bent rim prob. While the car is jacked, try grabbing the top & bottom of the tire and pulling one side while pushing the other to test the ball joint.
PS: I did NOT have a "clunk" sound over bumps with my bad ball joint as one person suggested earlier......
Old Apr 3, 2010 | 01:13 PM
fobstylez's Avatar
yeah I'm pretty sure its the axle, I just gotta find out which one by taking the boot apart. Ive done a lot of research and even people on the CL side seems to have had this problem. When it shakes, the steering isnt jerking left and right, just straight. Tires has been changed and balance, on both my stock and aspecs, still shaking. Changed my front struts, even swapped my eibach with my stock springs, vibrating still there. Checked all ball joints, no foul play. Mounts has been changed about 3 months ago. But yet vibrating is got bad after the weekend so this week I will take off the boot on the axle and see which side needs to be replaced if not both. I'll update after that is done.
Old Apr 3, 2010 | 01:16 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Re-balance your tires on a Hunter Road Force Balance machine, and see if that helps.
Old Apr 5, 2010 | 04:03 PM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
so, vibration under acceleration, mostly at highway speeds, is a probable indication of a bent axle(s) then?
Old Apr 5, 2010 | 06:30 PM
fobstylez's Avatar
from what I read, because once you let off the gas then the vibration is gone, so people can stop posting about checking your tires because tires will cause vibration regardless if you step on the gas or not. I just ordered a new axle from autozone for 69 a pop, you can get a manufactured one for 59 but for 10 bucks more, ez. It doesnt come until wed and thurs my bday and friday-sun I'm going on vacation so I probably wont have time to change it this week. If I dont get lazy I will post a DIY, MAYBE.
Old Apr 5, 2010 | 06:32 PM
ANC297's Avatar
Bonki' Ehrite!
Please do. l0l.
How do you know which side you need?
Old Apr 5, 2010 | 07:56 PM
fobstylez's Avatar
Please do. l0l.
well the outer portion, you should check the boot to make sure its cracked, if so then your cv joints are bad but you should be able to tell by the noise but the inner ones you have to take off the boot to look at it, from what I read. I'm just going to change both, I'm thinking its the drivers side axle from feel.
Old Apr 5, 2010 | 08:00 PM
myTLgoesBWAAH's Avatar
its just a balance u need bro
Old Apr 5, 2010 | 08:22 PM
fobstylez's Avatar
did you not read the posts? Tires has been balanced on BOTH MY RIMS, i'm going to stop posting on this due to idiots not reading this tread and jumping to conclusions.
