vac line
Old Mar 13, 2009 | 04:57 PM
iwantacleantl's Avatar
vac line
can some 1 please post a picture of the vac line as i want to seafoam my car and i have no clue wich line in being spoke of
Old Mar 13, 2009 | 05:01 PM
tlveteran's Avatar
you could find it on youtube.
Old Mar 13, 2009 | 05:45 PM
SLushhYYY's Avatar
Keep It Simple in
go to the seafoam thread.......
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/diy-seafoam-2nd-gen-tl-sorta-work-progress-631398/
go to the last page
Old Mar 13, 2009 | 07:00 PM
01tl4tl's Avatar
Remove plastic engine cover
its the main vac port at the TB
its the only hose with a squeeze clamp you can remove with your fingers
Follow the directions i posted, use Deep Creep if possible so you can clean the TB plate with it as well and its way eaiser than the hose and bottle method
OK to do a fast idle speed held while foaming the vac port
Just put in small amonts at a time to avoid stalling the engine
Warm engine is critical- and afterdrive to blow out the loosened gunk
Old Mar 13, 2009 | 07:02 PM
01tl4tl's Avatar
I would never trust youtube over the ziner DIY- unless a ziner post the TL seafoam DIY online~
There are several ways to do it- some work better than others
1- 16oz. can in 1/2 tank of gas is best, and 1 can in the intake vac port
noobs repeat in a month or 1500-2000 miles then good for a year
MrHeeltoe
20
Feb 23, 2023 01:54 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
