V6 Timing Belt Video Step-By-Step Replacement
Timing Belt J Series V6 Step-by-Step Instructions for the Honda Acura J Series engines. Hope this helps someone complete this job.
takin care of Business in
Received 4,732 Likes
great video....
Unregistered Member
2 comments:
1. The crank bolt does NOT come off that easy. I don't care how much penetrating oil you use.
2. He hand tightened the crank bolt. You should really at least get it to 150 ft-lbs. The factory spec is 180 ft-lbs, so hand tightening it a bit isn't going to cut it.
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
