V-TEC does not "kick in" ever by definition
Old Oct 9, 2002 | 09:27 AM
ExOwner's Avatar
odd that some people seem to think that vtec magically kicks in or otherwise. it doesn't.
vtec is a system, not a state. there are 2 profiles on the tl: low rpm profile and high rpm profile. at a certain rpm it switches from one profile to another.
let's say you set it up to always operate at the high rpm profile. you'd loose torque at low rpm which would make your car more slow.
vtec makes your car perform well at all rpm levels. it's always there, always working, always "turned on."
considering vtec to be "off" at low rpm is ridiculous. that's like saying your transmission is off unless it's in 5th gear. it's like saying your headlights are off unles syou have selected high beams.
the high rpm profile is no better or worse than the low rpm profile. you should be happy vtec does not "kick in" at low rpm vecause if it did your car would run rough and be slower.
if you want a way to verbalize what happens when vtec switches to high rpm profile at 5000 rpm or whenever it does, the correct way is to word this something like "my exhaust started wailing when my vtec switched to high profile."
Old Oct 9, 2002 | 09:49 AM
ExOwner's Avatar
Here's a link that helps explain:
http://www.howstuffworks.com/question229.htm
Old Oct 9, 2002 | 10:23 AM
ABDomega's Avatar
2011 SH-AWD 6MT
shut up
Old Oct 9, 2002 | 10:26 AM
IXLR8TL3.2's Avatar
HAHA, good for a laugh in the early afternoon
Old Oct 9, 2002 | 12:02 PM
Wow.......can we all say.."know it all"?
I agree with ABDomega.....
Old Oct 9, 2002 | 12:21 PM
Eternal TL2k3's Avatar
nothing wrong with him giving correct information... thanks bud... greatly appreciated
Old Oct 9, 2002 | 12:42 PM
SwampGas's Avatar
/etc/car
The default state of VTEC is low RPM...so when someone describes it as "kicking on", they're referring to the change to high RPM. As in, "kicking on high RPM mode".
Not to mention you can definitely feel the car "kick into something" because it suddenly takes off.
Old Oct 9, 2002 | 12:53 PM
car_lost's Avatar
thanks for the info ex... i always thought it only kicked in at higher rpms. now i know its always on but u only feel it more at higher rpms.
Old Oct 9, 2002 | 01:32 PM
doopstr's Avatar
So I realized that when I got my ticket doing 85 that my VTEC was kicked in while in 3rd gear
or
So I realized that when I got my ticket doing 85 that my VTEC was in high profile while in 3rd gear.
Sounds to "Harvard" for me.
Old Oct 9, 2002 | 04:31 PM
samkws's Avatar
Comptech Freak
hahaahha
Old Oct 9, 2002 | 04:49 PM
Mr Hyde's Avatar
Yup there is a high cam profile and a low cam profile. The new 2.0 liter 4's have i-vtec which is continuosly variable for max gains across the rev band where as ours are still much more aggressive up high.
I agree with everyone else. Its much much easier to just say "then Vtec kicked..." than it is to say "then the Vtec switched from the low RPM cam lobe to the high RPM cam lobe...." but that does easily allow people who dont know about the system to get confused.
Also the VTEC system is different between cars as well. Some Civics like the Hx for example have their systems geared for max MPG. Accords, Civics, are geared for both acceleration and MPG and have less noticeable switch over points. while the GSR, S2000's, NSX''s are very aggresivley geared for acceleration, and have very noticeable switch over points which almost feels like a little extra boost kicking in.
Old Oct 9, 2002 | 05:52 PM
baggsTLS's Avatar
Mr. Self Destruct
I always say, "Dang, when 3rd gear kicked in."
who cares what you say? we all know what we're referring to.
Old Oct 9, 2002 | 06:10 PM
mp3coupe's Avatar
Re: V-TEC does not "kick in" ever by definition
"vtec makes your car perform well at all rpm levels. it's always there, always working, always "turned on."
This is not true. Depending on the yr and model... VTEC "Variable Valve Timing and Lift Electronic Control" is controlled by the ecu/pcm. When the car hits its 'RPM" say 5K. The VTEC Solenoid kicks on! When this happens it allows oil pressure to flow through the passage…. it moves a pin on the rocker arm locking the adjacent one making it as one allowing the valves to open further by riding on another cam lobe. When the car is below say 5k RPM there is no oil pressure flowing through the passage therefore the valves aren’t opening up all the way..
Therefore VTEC does kick on and off. As for always working….well I’ve replaced about 20 or so VTEC solenoids. so it doesnt always work
"considering vtec to be "off" at low rpm is ridiculous."
now is it? what about the valves that arent opening?
Im sure you say that your alarm clock went off this morning... well if it beeped or played music didnt it turn on?
Old Oct 9, 2002 | 06:34 PM
Hey Sally Sensitive,
Are we actually getting politically correct on VTEC now??? Are people getting offended by the improper use of the term. For the love of God.
-Dang
Old Oct 9, 2002 | 07:29 PM
samkws's Avatar
Comptech Freak
those GS-R, S2000 have a stronger feel of kicking in coz of they have twin cam...
that's the effect of switching camshafts so u feel like VTEC kicking in
Old Oct 9, 2002 | 07:33 PM
ChucksCL-S's Avatar
I don't think there is anything wrong with us saying 'I hit VTEC and.." soforth. It's one of the coolest things about our cars.
Old Oct 10, 2002 | 09:03 PM
tuRb0mikEy's Avatar
Who Needs a Type-S?
Wow Exowner thanks for that great explanantion that made you seem so knowledgeable to all of the dumba ss newba here. Not even the normal newbs, but to the D U M B A S S newbs
Old Oct 11, 2002 | 07:57 PM
fla-tls's Avatar
On the way!
Re: Re: V-TEC does not "kick in" ever by definition
Originally posted by mp3coupe
When the car hits its 'RPM" say 5K. The VTEC Solenoid kicks on! When this happens it allows oil pressure to flow through the passage…. it moves a pin on the rocker arm locking the adjacent one making it functional allowing the other set of valves to open. When the car is below say 5k RPM there is no oil pressure flowing through the passage therefore the valves aren’t opening...
Are you saying that when the engine is below the +/- 5,000 RPM mark there is only one intake valve opening?
Essentially an 18 valve engine - instead of 24?
Old Oct 13, 2002 | 02:26 PM
ChucksCL-S's Avatar
Fla-tls No, both intake valves open at all times. In the VTEC mode the valves follow the cam lobes that open them for a longer period of time and also more deeply to use the faster flowing air rushing in at high RPM's. At the low RPM's you don't want that- the valves are following the standard cam lobes which aids with good low end torque and MPG. In VTEC we're saying "give me the air and fuel and RPM's because my right foot is looking for horsepower!". The exhaust valves only follow one set of lobes.
Old Oct 13, 2002 | 03:21 PM
y2ks2k's Avatar
God, I knew this back in 91
Old Oct 14, 2002 | 09:32 AM
jimcol711's Avatar
we all know the ricers love to go vtec-ing!!!
Old Oct 14, 2002 | 05:31 PM
fla-tls's Avatar
On the way!
Thanks for the response.
FYI - y2ks2k, there actually is a VTEC variant that closes off one intake valve at low engine speed. It's VTEC-E, which was used on the Civic HX (the first one to have a CVT tranny). It was designed solely for fuel efficiency.
Old Oct 24, 2002 | 10:20 PM
Raheel's Avatar
mlody
Dec 4, 2019 02:11 PM
emailnatec
29
Sep 28, 2018 04:27 PM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
