V-AFC owners....
V-AFC owners....
Ok,
I got it installed and everything is good EXCEPT my RPM meter(monitor) it's all fu*ked up, it reads 4869 when I'm not even gassing, then when I gas it it reads 4870 peak. What is wrong here??
Am I suppose to hook up the VTM wire???
tanner
13" Teady Bear Ronal Wheels, 185/70/13 Fulda Tires,
Dual SuperTrapp Exhaust, 2" Cut OEM Springs,
Shopping Cart Racing Wing, Triple Blade Wiper's...
tanner
yes tann you are. you cut the vtm connection and it is hooked up from the vafc to the computer. the other connection can be terminated. also make sure you select the right car type which is 6 cylinder and that the arrow for the throttle is pointing at 2 o'clock.
ar
ar
STANLEY TORONTO
07-21-2005 06:46 PM
