urgent!!!where to connect the error reader/scaner????
Old Jan 16, 2006 | 06:02 PM
arm5262's Avatar
Guys...
I urgently need to find out where to connect the error reader or scanner ? I went to autozone but the technician could not find the connector. He tried looking for it close to where we have the foot break.....please helpppppppppppppppppp!!!!!!!
I am hoping to go back to him tonight if i find a quicker reply
Old Jan 16, 2006 | 06:10 PM
demolition_x's Avatar
Agean Blue Bishes
under the coin tray theres another tray... . theres a black peice of plastic. reach behind it and pull. the reader is behind there.
Old Jan 16, 2006 | 06:42 PM
Bambo2888's Avatar
they go wooooot wooooot
to clarify, under the ashtray...
Old Jan 16, 2006 | 06:57 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Under the NOT AN ASHTRAY
Old Jan 16, 2006 | 07:28 PM
arm5262's Avatar
thnax guys for the help....i finally located it with the help of the clues you guys gave...got the error erased...was "auxialry emmision control"...any idea what is it ?
Old Jan 16, 2006 | 08:15 PM
03CoupeV6's Avatar
Loose gas cap?
Old Jan 23, 2006 | 05:42 PM
MikePA's Avatar
Not to be dense, but which direction do you pull in? Back towards the shifter? It seems to require some force to remove. I want to make sure I don't break anything.
Old Jan 23, 2006 | 05:45 PM
03CoupeV6's Avatar
Is your car a 99-02 or 03?
Old Jan 23, 2006 | 05:56 PM
03CoupeV6's Avatar
Okay...
If your car is a 99-early build 2002 then reach behind the plastic under the coin tray and pull towards you. It should snap out.
If your car is a later build 02 or an 03, it's underneath the dash in the driver's side footwell.
Old Jan 23, 2006 | 06:00 PM
MikePA's Avatar
99
Old Jan 23, 2006 | 06:03 PM
03CoupeV6's Avatar
You won't break it.. just give it a tug and it will snap out. One thing I noticed is that after I snapped it out that first time, it's never as tight again - but it won't break. It'll be easier next time you have to snap it out, though.
Old Jan 23, 2006 | 06:24 PM
MikePA's Avatar
Thanks!
I filled the gas tank yesterday and got interrupted by someone just as I was finishing. Forgot to put the gas cap on. Even forgot to close the door.
Since all this happened after dark, I didn't even notice until I went to get in the car to come home from work. Oddly enough, the Check Engine light didn't come on until I had driven 50 miles without the cap. I went back to the place I filled up and they had the cap! I used my Car Chip to reset the Check Engine light.
Old Jan 23, 2006 | 06:52 PM
03CoupeV6's Avatar
I left the gas cap off once and it took my car using up 1/2 tank of gas before the CEL came on, which was odd.
Old Jan 23, 2006 | 07:06 PM
Agean Blue Bishes
did you loose the cap?
that would suck...
Old Jan 23, 2006 | 07:21 PM
PlatinumTL's Avatar
don't do what I did guys, when you pop off the cover for the connector. I didn't know the whole thing lifted out and I had some coins in it. As soon as I popped it off, like 10 coins dropped into the cavity.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
