unusually specific code
I keep pulling a P1457 code. The description is "Unable to pull fuel tank vacuum". That is and incredibly specific description. So the question is should I be checking for holes in the filler neck and tank. Or? I replaced the gas cap a couple months ago.
I remember watching a long video by BriansMobil1 on YouTube on how evap systems work and what is the problem when you dont have vacuum.
Found this:
Found this:
did you use a Honda Genuine gas cap or some off brand?
Some things the TL is very picky about
How the system works:
vid player probs here- I defer to your knowledge on the subject
The gas cap is just one from advanced auto. 01acls the description for p1457 that you posted I have seen before with the same device that pulled the attached code. thelastaspec unfortunately I have not had time to check the piece in the video you posted. A friend has had my tl for two week and when it is at my house im either to lazy or at one of my two side jobs. But I will get to it probably at the same time I build the evap smoker I wanted to for a while. My confusion as the title and first post said was how specific the "generic" description was.
This is a dashcommand code.
I would trust the service manual more vs the app in case they wrote the description wrong. Fuel tank vacuum is the EVAP canister so I understand from brians video that i posted (the one that explains how they work)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
