Type-S Torque Sensitive power steering
Old Feb 11, 2001 | 10:30 PM
Guest
Guest
Posts: n/a
Question Type-S Torque Sensitive power steering
The March 2001 Car&Driver article (pg 83) states:
"The crowning touch, we think, is the replacement of the TL's speed-sensitive power-steering assist with a torque-sensitive system that offers much better road feel to the enthusiast driver."
What is "Torque-sensitive" power steering? How will it work? I assume at low engine torque times, the power assist will be high, and then at high torque times it will be less assisted. (Parallel parking, low engine torque, high power steering assist.) Is that right?
But what about when you are coasting down a hill, foot not even on the gas pedal, high vehicle speed, but low engine torque. In that situation, would power assist be high? (Eeeek!! A slight turn of the wheel, and you drift off the road.) Conversely, when I am turning onto the street, low vehicle speed, but high engine torque, then the power steering assist would be low, hard to turn the wheel. That doesn't sound good either.
Anyone know how this system really works, because I am an engineer, and this has me stumped.
Old Feb 12, 2001 | 07:31 AM
Road Rage's Avatar
Not a Blowhole
Post
I to am an engineering type, and this smells of the marketing folks' ignorance. I am sure they mean speed-sensitive.
Old Feb 12, 2001 | 08:08 AM
jhalderman's Avatar
Post
The torque-sensing is the torque you the driver is applying to the steering wheel-not the engine torque.GM calls their version Magasteer.
Old Feb 12, 2001 | 07:44 PM
Guest
Guest
Posts: n/a
Post
OIC. Now that is so obvious. Thanks! I never thought it would mean THAT torque, since that is what is assisted by the power steering feature. Must be some type of "looped" circuit. Cool!
Old Feb 15, 2006 | 10:13 PM
zibadun's Avatar
I'm still lost. Can somebody explain in idiot terms the difference between Torque-sensing and speed-sensing steering? tnx
Old Feb 15, 2006 | 10:57 PM
Leviathan's Avatar
Holdin it down for MS
Five year old thread revived!
Old Feb 15, 2006 | 10:58 PM
Pure Adrenaline's Avatar
Dragging knees in
From what I remember...
On speed-sensitive, the power steering assist boost is relative to the vehicle speed.
On torque-sensitive, the power steering assist boost is relative to the engine speed (RPM).
It's all possible by a variable-ratio power steering pump that can vary the force of hydraulic pressure to increase or decrease steering assist.
But I'm not 100% sure, so don't quote me.
Old Feb 16, 2006 | 09:29 AM
zibadun's Avatar
Or does torque-sensitive mean there is a sensor to detect how much resistance wheels get from road surface while turning?
Old Feb 16, 2006 | 02:20 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Here is the explanation of speed-sensitive:
http://www.canadiandriver.com/articles/jk/at_010327.htm
Here is the explanation of torque-sensitive from Honda:
Rack and Pinion Steering With Improved Stability and Reduced Kickback
The Accord's well-weighted and highly responsive power rack-and-pinion steering system provides an exceptionally linear and consistent feel regardless of pavement conditions. The Accord's power assist is steering-torque sensitive; hydraulic boost is applied to the system in direct proportion to the amount of force (torque) created between the tire and the road as the wheel is steered.
As the force increases, the system increases the amount of power assist accordingly. Regardless of speed, an increase in effort is countered by an increase in boost (for example, if the wheels encounter a rough surface with a greater coefficient of friction).
Source: http://www.hondanews.com/CatID2006?m...36652&mime=asc
Now maybe this 5 year old thread can
Old Feb 16, 2006 | 08:12 PM
zibadun's Avatar
Thanks 03C, it now makes the perfect sense. I guess I wasn't using the right search terms. RIP
Old Jan 11, 2008 | 03:56 PM
k9500winmag's Avatar
i eat ricers
all i know is that in my 96 TL when i hit the gas (even at speed) i get torque steer pretty bad. especially noticable on the interstate when i drop a gear and stomp it. course it also breaks traction to the front tires half the time when i do this...
Old Jan 11, 2008 | 06:42 PM
Gfaze's Avatar
S E L L
Almost 7 year old thread brought back from the dead.....a 2nd time!
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
