type s engine peak power
Old Dec 23, 2005 | 09:11 PM
gcjin2007's Avatar
this might seem like an illogical ques, but ill ask anyways... im about to go up to pa. tommrow and wonderin at what rpm range will i see the speedo "fly." the type s engine specs 232 lbs. of torque at 3300-5500 rm and 260 hp at 6000 rpm, so will thw speedo "fly" at 6000 or 5500? o ya btw, im not crazy, im only gonna try this out whenn pulling away from a toll booth w/ sportsifht in 2nd gear, and let of the gas after i redline to take and easy on the 2nd-3rd problamatic clutch.....
p.s. i know this ques is kinda dumb but it could turn interesting, so answer anyway
o ya, what tire psi should i be runnin for best fuel economy.
Old Dec 27, 2005 | 06:55 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
once the vtec kicks in you will notice that the speedo moves quicker, but in general i think you find the 5-7k range to be slower than the 1-4k range on your tach. considering the peak torque is pretty low though (~2250rpm per my last dyno), i think that you may end up being more impressed with your 'off the line' acceleration.
i found that once i put headers in that the car moved alot faster around 6k rpm's.
SSTS
Old Dec 27, 2005 | 09:37 AM
fsttyms1's Avatar
SSTS
way to contradict your self
to answer your question, stay in the peak HP range and that is where you will be the fastest.
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 03:16 PM
Phambam12
Sep 6, 2015 06:57 PM
