Turning signal light, help!
My both side headlights and driver side turning signal light have gone out for a while. I got trouble to remove the turning signal light bulb. It seems that I need to remove the bumper first. Is the turning signal light bulb special? If it is, where can I get the good price one. Thanks!
Depending on what you actually drive....
The inner panel in the fender unclips and pulls down to reveal the turn signal bulb
Just ask the parts store for the correct one for your year.
The headlights are also replaceable without removing the bumper umless you are replacing the entire light housing- not just the bulb
The headlight bulbs are pricey like 100-150$ per pair
our vendor Excellerate in the Off Topic area- sponsored sales- scroll up to the top of any page and you will see the off topic link, has great replacement bulbs for the TL and others
Search feature will take you to many DIY tips on these projects
Good Luck!
Good Luck!
Thanks!I have removed headlight bulbs. They are done. I need to order a new pair. I still can not remove the turn signal bulb. Mine is 99 TL 3.2. What should I do then?
I have an 01 and they description I gave should work- look on the edge of the plastic fender liner for some removeable clips and pull the liner down
Should be right there for you
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
