Turning radius for TL vs TLS different, why?
Old 10-30-2003 | 10:27 AM
yoda's Avatar
Question Turning radius for TL vs TLS different, why?
Folks why does a TL-S have a different turning radius then a standard TL?
19.4' vs. 18.4'
I thought the 2 cars suspension were identical. The only difference between the S and non-S was the engine output. Is the suspension different?
Seems kind of weird that a non-S has a tighter turning radius then an S model.
Thoughts? Comments?
Old 10-30-2003 | 10:28 AM
Pure Adrenaline's Avatar
Dragging knees in
Suspension is different between P and S.
Old 10-30-2003 | 10:31 AM
yoda's Avatar
WHat are the differences?
Thanks.
Old 10-30-2003 | 10:38 AM
kent_99TL's Avatar
Stock rims size and tires size different. 17"/16"
Old 10-30-2003 | 11:46 AM
Different rims, tires, shocks and stabilizers. The VSA may have something to do with it too.
Old 10-30-2003 | 11:55 AM
yoda's Avatar
Ah, I knew about the different size in rims/tires. But that would not effect turning radius.
I did NOT know that the shocks & swaybars were different. What about the springs?
Does anyone know if the ratio on the rack & pinion are just different? And if so, why the change?
Rim Size, Tire Size, shocks, springs and swaybars would not change the turning radius. The rack & pinion would. The question is why the change I guess. And what other suspension differences are there?
Old 10-30-2003 | 08:17 PM
Allout's Avatar
Blown is Best
Springs are different also.
I didn't realize the different turning radius. Has to be in the rack.
Old 10-30-2003 | 08:31 PM
drcookie's Avatar
With wider and bigger tires in TL-S the steer box was set not to have the wheels turn too much or risking the tires scratching the body.
Hope this helps.
Cheers !!!
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
ROSSARONIE
10-02-2015 11:46 AM
Brandle34
09-23-2015 07:20 PM
Quick Reply: Turning radius for TL vs TLS different, why?
