Turning circle radius
Old Aug 18, 2005 | 06:27 AM
Nick's Avatar
Why hasn't Acura tightened the turning radius for the car over the years? Perhaps one of you mechanically inclined guys (or gals) could explain this. Isn't it just a matter of letting the steering wheel turn a little further? Is it a matter of the front wheels not having enough clearance in the wheel wells?
Old Aug 18, 2005 | 06:34 AM
chewi's Avatar
BTW... do u have the TL-P or TL-S.
The TL-P has the advantage of smaller turning radius in which they can make smallers U-turns, while the Type-S has a larger turning radius.
Anyways... My friend Michael had his TL-S brought into an acura dealership for an alignment. They also made his turning radius smaller like the TL-P or even better.
You have to make a request to the Dealership for this.
I hope things will work out for you.
I'm planning to get the same thing done for my alignment next month.
Old Aug 18, 2005 | 06:40 AM
Nick's Avatar
got the 02-S -- thanx for the info, never thought to ask the dealer! perhaps the next time i'm in for maintenance ...
Old Aug 18, 2005 | 09:25 AM
fsttyms1's Avatar
im calling on this. the only way to do that is to either change the powersteering rack to one that has different (tl-p), or do modifications to the tie rod mounts on the spindle (none of which the dealer will, or could do under a alignment or cheap. the power steering rack new is over 650.00)
Old Aug 18, 2005 | 10:15 AM
Pure Adrenaline's Avatar
Dragging knees in
Agreed.
It would require changing or modifying the rack and/or pinion, and that is neither an easy nor a cheap task. And the dealership would never do this.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Brandle34
Sep 23, 2015 07:20 PM
