turn signal problem
turn signal problem
i was doing the led conversion, and i noticed that now my turn signals wont work. i left the stock bulb in there, and if i press the hazard lights the buttons light up so i know the bulbs are good. but, when i hit the turn signal, neither the arrows or the actual lights outside the car work. any ideas?
I just installed LEDs on my bike and had to install a LOAD Resistor or the flash rate was way fast. If the car senses a low draw it believes the bulb(s) to be burnt out and may trigger a non-op status and not light or try to stay on so you know there is a problem
Check the DIY thread on LEDs and verify if they say you need a resistor. Simple device probably found at computer repair shops for cheaper- I got mine here
http://cgi.ebay.com/ebaymotors/LED-T...1%7C240%3A1318
and some others to compare
http://motors.shop.ebay.com/items/lo...506.m104.l1199
online search found a bimmer forum that needed these to use LED license plate lamp,, or the dash indicator for bad bulb would come on
when you try the hazards you get light from the LED- not just a dash indication?
If you think it blew a fuse, try a new fuse, the spare or borrow one from another slot
about the resistor, i got the solderless kit of ledautomotive which says doesent need one.
also i didnt replace the turn signal bulb. when i hit hazzards the stock bulb lights up, but when i use turn signals nothing happens
I also just change the front turning signal bulb to LED. I have hyper flash now. Does anyone know where to mount the load resistors? It is said that they should not be mounted with plastic or paint surface.
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
