tune up questions
tune up questions
ive almost had my car for 1 year and its time for a tune up. What should I replace besides my spark plugs. I currently have 127k on my car and ive replaced my oil and coolant about 2 weeks ago.
hondakid23 (02-05-2012)
S E L L
When you do the 3x3, you drain the transmission, fill with 3 quarts, drive the car around for 5-10 minutes, repeat. Do this three times, hence 3x3. Make sure you use OEM fluid (ATFZ-1 or the new fluid DW-1) from the dealer. Try a Honda dealer as they sometimes have the same fluid a little cheaper than the Acura dealer.
i heard you shouldn't change the transmission fluid after a certain amount of miles just add because it can cause problem is this true or anybody heard this before also i had a friend change his and a few days transmission shot that i witness but not sure if that was the reason
Unregistered Member
kill you till you die
air filter, in cabin filters, check power steering fluid and brake fluid color, look for wear on your belts, seafoam the oil gas and the intake manifold and clean the throttle body, clean EGR and check the PCV and replace if needed.
was the `105`kmiles = timing belt water/pump job replacement done?
how did the coolant look- that will tell you quickly,, as it gets replaced with that service!
was it 10 years old or 2-3?
you can do seafoam at 1 16ounce can to just under a half tank of gas,,twice
,,and spray carb cleaner on the TB air inlet plate (see diy),,if you have concerns over the intake manifold vac port method for seafoam ,,
twice in the gas as described- gets all the same things plus more!
that stuff is tune up in a can!!
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
