TSX Projector Retrofit
I have a spare set of headlights that I opened up and blacked out. Since I had them opened I decided to use the TSX projectors I've had for quite some time. I gave them to a local shop that does retrofits and he was saying that I will need a new HID kit to use with these projectors.
Do I need to buy a new HID kit or can I just reuse the OEM ballast and ignitor?
I will post pictures of the headlights when I get them back. Should be done sometime next week.
I retro-ed tsx projectors and I ran aftermarket kit as well. It depends on how he is mounting it and if it sticks out the back. I guess you have to see how he did the retro. I just ran aftermarket because any leak would blow your ballast but like I said, it depends on his work
yea mine sits a bit back a bit from the front and considering how long they are, it sticks out the back of the housing so it was ez to run an aftermarket kit. I just bought a generic kit off ebay, over a year with no problems or leaks. Still have to adjust them a bit, been lazy cause its so cold, and i'm lazy
Traded in my
So how are these turning out? Get some pics up when you get them back so I can see how they were mounted. I'm workin on a TSX retro too..slowly..and I wanna be able to use the OEM hardware.
fobs - PM me some pics of your setup. I may be hittin you up for some help while I work on this...
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
