Trunk Rattle Solution-lower Trunk Latch?
Old May 24, 2008 | 07:58 PM
nikep15's Avatar
Hey I have searched for solutions to my trunk rattling problem. And im considering lowering my trunk latch making the trunk shut tighter, so that it doesnt rattle as much....but before I do it I wanted to see if anybody has done this and what the outcome was. And any problems that you may have had in the process and if somebody could post instructions and maybe some pics. thanks
Old May 25, 2008 | 12:27 AM
02ACTcLean's Avatar
..PRAXIS..
Try this... take some cloth, fold it up 3 or 4 times over (not too thick or the trunk wont shut) and lay it over the latch hook ( the bottom piece). The folded up cloth should be about 4in. by 4in. Shut the trunk and make sure the cloth stays laid over the bottom piece. The tight fit keeps the latch from making any noise at all.
Old May 25, 2008 | 12:54 PM
oVerBoost's Avatar
HELP!
i lowered my trunk latch and it eliminated all my rattling problems. just remove the plastic piece held on by i think 4 screws. this will reveal the entire latch. then loosen the two bolts holding the latch, which will enable you to slide the latch up and down. In your case, you want to slide it further down. tighten everything up and replace the plastic cover piece. viola! you're done.
of course if you're bumping your music at insane levels, you're still going to have a little rattle even with the latch lowered. in that case, you might want to think about dynamatting the trunk....but if that's the case, other things such as license plate and fenders would be rattling as well
Old May 25, 2008 | 02:16 PM
6MTUA5's Avatar
No He Can't
I lowered my trunk latch a while back and it got rid of most of the rattles. The TL's trunk just rattles real bad for some reason so if you're running a big enough system I would just Dynamat it.
Old May 25, 2008 | 05:53 PM
nikep15's Avatar
i just lowered my latch it got rid of the rattling almost completely
Old May 26, 2008 | 08:49 PM
sfont012's Avatar
here comes the snow!
put a piece of cloth over the latch on the bottom part of the trunk and it worked great!!
Old May 26, 2008 | 09:38 PM
02type-s's Avatar
-Arsenic-
I just adjusted the rubber stoppers further down to make it shut tighter and it worked for me.
Old May 26, 2008 | 09:40 PM
Rajca's Avatar
wham bam thank you ma'am
i deadskined my whole trunk, well most of it, and it still rattle at the drivers rear quarter panel. so i just started to rip my whole trunk carpet out. found the rattle. two rubber pieces behind the plastic case looking thing on the left side. i guess its used for letting air in and out and keeping water out. i took it out and no more rattle and no water in the trunk yet.
Old May 27, 2008 | 09:18 PM
websters03's Avatar
same where. i think u should do the rubber stoppers first then latch if u still get rattle. JL12W3 no more rattle for me.
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
