Trunk Lifting Assembly
Has anyone replaced this with a pop-trunk setup or hydraulic shocks? Instead of that silly springed mechanism that takes up useless room under the rear deck?
because big ass subwoofer box & still wanting my golf clubs in there...it can be pushed further back but the amp is mounted to the top & I like having it hidden up under the deck.
I can figure out the static forces needed to do it, I just wanted to see what others have done to see if there are going to be issues or improvements to make instead of later.
doubtful but ill try to find something # wise. I know its about 7" (14" total) in length. The ends it clips to i got from the salvage yard. Just unscrewed them from a hood. Other wise you can get them from the dealer for about 5 bucks 85269-SH3-003 STUD, BALL. Im sure part stores carry them too.
Fatty, if anything just measure total entended length from central axis of each mounting joint & the length of the shock body. I'm working the statics problem on a whiteboard as i type this.....if I can find a shock that gives the almost perfect force to lift a stock trunk then i can run that setup & then recalculate given the trunk has been dynamatted (my case) and pick a shock for those with matted trunk lids....
I'm gonna give this a shot...I see the ball support attached to the trunk arm, but hard to see how that and the one at the base are attached.
The one on the arm...did you drill thru the arm? Is there a support ball that will accept the bolt thru the arm? You can tell I'm not real good at this kinda thing...
I used a piece of L bracket and fastened that to the metal cross member behind the seat and attached the ball to that. On the trunk arms i drilled a hole thru them to attach them. There are other options or methods that could be used, i just went that route.
Say...I see you live in Wisconsin...I'll fly you to Seattle to do this for me! But let me give it a try first.
Did you use self-tapping bolts to attach the L bracket to the cross member, or nuts and bolts? Not a lot of room to work in there...or did you take the back seat out? Man, I need all the help I can get on things like this...
I took the seat out but some self taping screws could be used as well im sure
Also, re the ball studs...are those studs threaded to receive a nut and washer on the open end? Acurapartswarehouse.com has them, but there's no pic.
Happy Turkey!
Jul 16, 2017 07:33 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
