Trunk Leak (in the strangest place)
So about a month ago I found out that there was a leak in my trunk. I thought it was strange that the trunk liner was damp until I took it out and saw that my spare tire was COMPLETELY submerged. Yes,.. the entire wheel well was full of water. After draining it, drying it out completely, and removing the liner I let it sit through a rain storm and found a strange source for the leak. Apparently the water that drains from the well around the trunk seal is somehow seeping back in through the underside of the taillights. It's a slow leak (about an ounce for every two hours of rain), but I don't know what to do about it. It almost seems like the foam seal that is between the taillight and the body is what is drawing the water in. If I can snap some pics I'll post them here.
Has anyone else experienced this before? Any advice?
Thanks!
Thanks!
Fuz, I have the exact same problem you are describing, exactly. Leaking thru the tail lights. I popped the trunk liner off to see what where the water was leaking, but that didnt help because the leak is between the light and casing as you described. My donut was underwater too and it splashed into the back seat, causing mold, geesh,
TO ALL DEALING THIS PROBLEM: There is a plug in the spare tire compartment, take it out. This will keep the water from building up like the OP mentioned. Even if you don't have the leak, if you ever get the leak, it won't flood your trunk causing mold everywhere. I have never had the leak and took mine out anyway, have no problems with water coming in from the outside...
Well I tried to create a silicone seal for one of my lights (I just had half a tube of silicone to work with) as a test, and it was more difficult than it sounded. Anyway,.. I can't get away from the rain (and work) long enough to do an adequate fix. But the good news is that I found the OEM seals here for $9.52 each. I'm getting ready to order them, but I think I can find the material cheaper at NAPA and make them myself.
As a side note,.. I'm considering removing the rubber grommet at the base of the spare tire well, but the reason I'm not is a matter of principal. I know it's stupid,.. but a trunk should not leak, therefore I want to find the cause and fix it properly instead of just creating a workaround.
Another thing,.. I think I might be getting an additional leak from the air exhaust vent on the drivers side in the trunk. If you have ever removed the trunk lining then you will know what I'm referring to. I think the foam gasket on that is failing too, but that one is going to be more of a pain to fix. We'll see.
One more thing... I've been trying to get the damn trunk liner all the way out, but the last retaining clip/bolt is killing me. It's the one that is between the trunk and the back seat. Does anyone have any hints as to what's the easiest way to get this last clip/nut removed? I figure that I have to go and take the back seat out, but that sounds like a pain. And, yes, I've searched, but it hasn't yielded much. And before anyone asks,.. I know that I don't have to take the liner out all the way, but I want it to dry completely,.. and it can't do that in the current situation.
Replace your tail light gaskets. I have suffered the same problems with all acura/honda's. I have tried the silicone around the tail light openings and it will not work or last very long. Gaskets are cheap and easy DIY. Hope this helps.
http://www.acuraautomotiveparts.org/...s=&view=normal
12volt Technician
1 Post
exactly what i did after finding the swimming pool in my trunk!!
T-Swzy
i had the same problem. be sure to spray it down with lysol, wipe with soap, spray lysol again and wipe with soap. wouldnt want any mold growing in there with the moisture
'06 Acura TL
Hey, I have this same problem. Is there any chance that its just the plugs under the spare are really old and corroded and water is splashing up into the car from underneath?
In my case it is not the gaskets around the tail lights and its not the lines coming from the sun roof. There clear...
Need an OEM lip kit on my
Same problem here too...spare tire submerged It happened when I tinted my tails and didn't properly tighten them back
I just tightened the taillights and made sure the leak was gone by dumping water over the trunk with no liner or tire in there to make sure the leak was gone for sure.
Same spot you're talking about. The seams under the edges near the hinges. You ever figure out what was causing it? I cant find the problem myself. Thanks
USAF Veteran
This thread is from 2009. I suggest you start a new thread on it.
Meanwhile, I had the leak as well. Here's my thread on it.
Turns out mine was the tail light gasket but I checked all other leak points.
https://acurazine.com/forums/2g-tl-p...trunk-1002919/
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
