trunk CD changer for 2000 TL
I want to buy a trunk cd changer for the TL. Will any changer work (Alpine 4905) or do I have to get the OEM 2000 Acura TL one? Is the connector in the trunk a standard one?
Also, will a CD changer play burned CD's? Thanks!
It should work one way or the other; or get the plug for the back port, then tab into those wires and hopefully you could use your steering wheel audio control. Some experts will probably give you a better info. If you plan to use the control that comes with the cd changer, then I don't think it is a problem at all.
justin.w13.walker
09-22-2015 02:21 PM
