Is this true... Fuel strainer
Old Dec 10, 2004 | 08:31 AM
MINASTRILLA's Avatar
Is it true that the 02 TL-S has a fuel strainer kit and not filter. And if yes does anyone know how to do this or is there a DIY on this? Thanks.
Well here read this. This is were they specify.
Fuel Strainer Kit, Read what it says.
Old Dec 10, 2004 | 01:10 PM
Is it too much to answer people.
Old Dec 10, 2004 | 01:20 PM
fsttyms1's Avatar
im not sure wether or not it has a external filter, but to replace the strainer you have to open up the fuel tank, pull out the fuel pump and then remove the strainer.
Old Dec 10, 2004 | 01:32 PM
69ssrscam's Avatar
2003 SSM TLS
The way I understand it, this should not need to be replaced unless you have some unusual severe fuel problem. This is like the old "sock" mesh thingys that were on the old fuel sending units in the gas tanks.
Don't our TLs have a fuel line filter before the fuel reaches the injectors????
Old Dec 10, 2004 | 02:45 PM
ou sig's Avatar
Boomer SOONER
Ya one would think there would be an external filter, but I think that is all we have.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Old Dec 10, 2004 | 02:57 PM
fsttyms1's Avatar
#9 is the filter can.
Old Dec 10, 2004 | 03:35 PM
ou sig's Avatar
Boomer SOONER
damn you fsttyms1!!! I thought I was mostly right but you had 1 up me! Well I feel better, cause it wouldnt make sense for the only fuel filter to be in the tank
Old Dec 10, 2004 | 03:43 PM
fsttyms1's Avatar
hahaha ill let you take most the credit!
joflewbyu2
Aug 18, 2019 10:38 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
