Trip Reset Backlight
Old Apr 3, 2003 | 09:00 PM
mskeen's Avatar
Okay, does the trip reset button light up when the lights are on?
Sorry for the dumb question I just can't remember and the d@mn thing is out at only 65k miles, WTF?
Old Apr 3, 2003 | 09:06 PM
Comet2404's Avatar
Flyin' and Drivin'
yeah, its out on my '99 with 77K... so is the D light. Every other gear lights up, but that one... kinda makes me mad.
Old Apr 3, 2003 | 09:09 PM
fsttyms1's Avatar
my 00 doesnt light up
Old Apr 3, 2003 | 10:59 PM
SilverUA5's Avatar
The button doesn't light up.
Old Apr 3, 2003 | 11:01 PM
Tatewaki's Avatar
The buttons on my 99 lights up. Better check to see if the bulbs are blown
Tatewaki
Old Apr 4, 2003 | 03:11 AM
Aki's TL's Avatar
That whole section of lights (outside temp/mileage/trip A/B) and Sport shift gear light and clock light went out. I'm at 47k miles
It's covered under warranty... Just got it back today.
I hope you dont go through what I went through to get the lights fixed.
If you have the time, check it out yourself. there's three screw on bulbs that go into the gauge panel. To get the front dash out just unscrew the two screws under the top of the dash. Next gently pullout starting from the top. The left air vent may be the biggest obstacle other than getting your fingers inside to disconnecting the wire connectors.
The gauge panel is connected by four screws in the front and three wire connectors in the back. Once you get the panel out you'll see the three bulbs (red plastic). you might want to swap other light bulbs to see if they work in that area. If so just get replacement bulbs. If not then take it in - you may have a problem with the gauge circuit board.
good luck!
Old Apr 4, 2003 | 03:18 AM
Aki's TL's Avatar
If you do attempt to check it yourself, pop off the top plastic cover
on the steering column. You won't want to scratch that piece. Plus you'll need some room there while you are slipping the front dash out
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
2Quik
Sep 23, 2015 01:03 PM
