Transmission Question!!!
hey guys, i just recently bought an 03 tls with 80k miles on the original tranny. my question is, Is it certain that the tranny will fail or is it possible that it has no defects at all and could possibly last another 80K? I'm freaking out after reading all these stories about your transmission dieing. I bought the car with a salvage title, so am I still under the transmission replacement warranty? And lastly, what are the usual symptoms of transmission failure? thanks in advance guys!
-Mike
-Mike
Originally Posted by gc86
You're salvaged title so you're not covered under any circumstance by the dealer. Take great care of that transmission and flush replace the ATF regularly. Heat is what causes failure.
Originally Posted by Bob_F
You don't want to flush the transmission fluid. Drain and replace is recommended for the 2nd gen TLs.
never flush the tranny, and ONLY use honda ATF. try and find out if the tranny had ever been replaced before, and if it is the new revision.
Originally Posted by fsttyms1
wont make a difference and heat is the problem ONLY in the 3rd gear clutchpack. There is no way to make it cooler
edit: I meant drain and replace.. sry
BoricuaTL
Apr 8, 2016 01:08 PM
