Transmission Fluid Recommendation
#42
And so I completed the 3x3 (drive around after each change) over the weekend until the lightning/thunder/rain came which stopped me from doing the 4th. The trans slipped a little after the 1x3 and 2x3 changes, especially when coasting right after a turn. A couple of times, it seemed like the gear didn't engaged that I had to come to a complete stop, shift back to park then to D5 to go again. A couple of times, it slowly engaged after the slip but go again and I didn't have to come to the complete stop. It happened once right after the 3th change, when I took the drive around after the fluid change. I thought I have to bring it back to that shop after work, but no issue this morning drive to work. So, let's see if it happens again. Any idea why it slipped after the 1st, 2nd? Maybe the other fluid was still in there cause it?? Anyway, will do the 4th change after work today. Hope problem will go away. Thanks for all good comments!
mada51589
05-03-2022 08:54 PM
Mike Bertram
09-10-2015 09:27 AM
