Transmission Fluid Change and Stuff?
hey wassup guys..i just bought some Honda ATF-Z1 Tranny Fuild like 2weeks ago..but dam that shit is hella expensive...12 ct of atf-z1 for $70 total...
but anyways...i found some post that i found about changing the tranny fuild..i was wonder can i just drin da tranny fuild and put a new one in and i was wonder is there another way to put the fuild in beside putting it in were the dipstick is...
i know there is another way because when i took it to jeffy lube they took a bolt out and put new fuild in and i didnt look...but anyways...and one more thing can i just take it to the dealer and let them do it and how much would it cost me...
thanks guys......
all rights to "brake job" for this DIY...
here:
I'll make an actual DIY when I get home then, since i didn't find a very good one on here... but for now:
again: PICS coming soon to make everything easier
Definition for this DIY... Hand Tight = as tight as you can get it with a regular socket wrench without going overboard on the strength. ( unless you're a broly, then use your brain you meathead)
Tools Needed: (*=required, $=Suggested)
* 3/8" socket wrench
* 12mm Socket *OR* a 17mm Socket... 12mm if you have the oil jet kit, 17mm if you don't
* a jack and jack stands, or a ramp, or some way of accessing the underside of the car
* A funnel with a long spout
$ Hammer or a Breaker bar, because bolts can be on tight as fuck from acura
$ a bunch of extensions giving you about 12" of extension... it makes accesing the oil fill area MUCH easier....
* some sort of drain pan of course
Supplies needed:
* 3 or 4 quarts of ATF-Z1 per drain/fill... its about 3.1 qts from acura so I usually have an extra qt on hand for the extra .1...
$ Transmission bolt crush washer... similar to oil crush washer... some dont replace it, I do... YMMV
Instructions:
#1 drive the car 10-15 mins to warm everything up. get on it a few times and make the tranny work hard, go in SS and work through all the gears... just get everything hot and ready. This is very important, or else you WILL NOT get all of the fluid out of the tranny... a "slightly warmed" tranny will usually only yield 2.5 quarts of fluid.
#2 get some beer handy.
#3 get the car in the air (jack, ramp, whatever... try to stay as close to level of course)
#4 Look under the car. on the drivers side (right side of car if you're looking head on of course) of the engine you'll see a bolt with a 3/8" square in the middle, similar to a big ass allen bolt. Guess what goes in this square. well, besides your penis, insert your 3/8" socket wrench in there. If you can muscle it off like this, have another beer broly. Otherwise use your breaker bar or tap it with a hammer to loosen the bolt.
#5 remove the bolt, burning your fingers in the process (a required step), and drain the tranny fluid. smells good doesn't it.
#6 look at your fingers. they should be burned
#7 get a rag and wipe down the tranny bolt. That big black thing is a magnet, and will probably have a ton of metal filings on it. this is normal, just wipe it off... also make sure you're continuning to burn your fingers on this bolt, because it is usually FREAKING HOT. Replace the crush washer with the new one (if you bought one) and set the bolt aside for now.
#8 while the tranny drains/drips, we're going to open the filler. If you have the Oil Jet kit installed, go to 8a. If you're not in the oil jet crowd, go to 8b
#8a. Leaning over the driver's side fender, look directly under the air intake hose, or where the air intake hose would be if you still had one (cai,sri folks). Slightly to the right on top of the tranny you'll see a black metal tube connected to a small black hose, which goes right into the transmission. there is a bracket connected to this tube, anchored by a 12mm bolt. Use your socket wrench and socket to remove this. (If you dont have enough extensions, good luck getting it off. If you do have the extensions, its a breeze. Just extend the socket down through all the cables and tubes, and tap/breaker bar that wrench until the bolt comes loose. )
After you remove this 12mm bolt, pull up on the metal tube. it will probably be tight, but it will come off. remove the tube from the hole and let it rest to the side...
#8b Leaning over the driver's side fender, look directly under the air intake hose, or where the air intake hose would be if you still had one (cai,sri folks). Slightly to the right on top of the tranny you'll see a 17mm bolt (probably with some blue on it) in the top of the tranny. Use your socket wrench and socket to remove this. (If you dont have enough extensions, good luck getting it off. If you do have the extensions, its a breeze. Just extend the socket down through all the cables and tubes, and tap/breaker bar that wrench until the bolt comes loose. )
After you remove this 17mm bolt clean it off and set it aside. laugh because it's easier than the poor fucks who have the oil jet kit. go ahead, laugh.
#9 when the tranny stops dripping take that clean tranny bolt and reinstall it. Torque it to hand tight, dont go crazy. then wipe up your mess you damm slob.
#10 get that long spout funnel and insert it in the fill hole you just made in step 8. pour in 3 or 3.1 quarts of fluid. then wipe up your mess because you spilled ATF everywhere, you really need to learn how to pour fluids!
#11 replace whatever you removed in step 8.
NON OIL JET--> torque that 17mm to hand tight
OIL JET--> put the oil jet back in the hole, pressing down hard to ensure a proper fit, and replace the 12mm bolt. once the 12mm bolt begins to tighten down stop and press down on the metal tube. sometimes nothing happens (which is fine), sometimes it makes a small click as it seats under the pressure of the bracket (which means its now seated properly because you did not press hard enough the first time). tighten the 12mm bolt to hand tight.
#12 lower the car down and check the tranny level to make sure the fluids are at least in the tranny. The level is not accurate yet, just make sure theres something in there!
#13 check for leaks, and finish your beer. then take a leak.
#14 drive the car 10-15 mins, heating it up like in step 1. then, with the car off of course, check the fluid level. should be within spec
#15 pat yourself on the back or repeat, depending on how many changes you want to do in this sitting.
#16 seek medical attention for your burned fingers.
here:
Supplies needed:
Instructions:
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Mike Bertram
Sep 10, 2015 09:27 AM
