Transmission filter
Transmission filter
The owner's manual for the 2002 Acura TL specifies changing only the fluid, not the filter. Some sources argue that the internal filter does not need replacing. This is supported by EricTheCarGuy. Nonetheless, there are videos demonstrating filter replacement. Common belief holds that the filter should be changed along with the fluid, akin to motor oil, but it appears that many opt to replace only the fluid. What is the recommended procedure for this vehicle?
If you are not the original owner of the car, I would change the outside ATF filter ASAP, as I did on my preowned 03 CL-S automatic, which had 51K miles.
Even though the previous owner stated that the transmission had been rebuilt about 10K miles before I acquired it.
Obviously, you can't get to the internal ATF strainer assembly; therefore, it is what it is, depending on the previous owner's ATF fluid change interval frequency.![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
The 'go to' ATF recommendation here is the Honda DW-1, personally, because I like to live dangerously
, I opted to use the lower cost Aisin DW-1 available at RA for the best price per quart. No issues thus far in South FL's hot / humid stop & go environment.
![Crazy](https://acurazine.com/forums/images/smilies/crazy.gif)
DreamMachine (09-05-2024)
USAF Veteran
If you just purchased (or are planning to purchase) this TL, I would change all the fluids and associated filters unless you had recent service records showing they have already been serviced.
How many miles are on it?
Will be changing my external filter next 3x3 fluid change. My question is this filter an OEM or aftermarket? Seller is from Hong Kong. I can get an aftermarket for about $16 on AliExpress.
https://www.ebay.com/itm/40501225212...mis&media=COPY
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
There is no way to know or tell if that is a Honda OEM factory filter & the price is ridiculous, IMHO.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
The rockauto Beck/Arnley one below is what I used 3 years ago & will be the one I use next year when I change the ATF filter again.
It will fit your 2G TL even though it's not listed, just take the OEM part number and part number search to confirm, if you want.
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/1303x204/screenshot_2024_09_03_154250_c10f5bc504b40252553f7d2efc31da396ff879ab.png)
that looks fake as shit..
Peter Gozinya
08-04-2023 11:57 AM
