Transmission Drain Plug Stuck
Old Apr 16, 2021 | 10:09 AM
Cheekeman's Avatar
Hello all again,
I've given up trying to get the drain plug off for the transmission. Took it to a shop I am near and they can't get it off either. Is there any other way I could possibly drain the fluid? I assume I might need to take a line off or something. Wanted to see if this has happened to anyone on here. One place I called said they can "flush" it out but I didn't like the sounds of that. Any help is appreciated. Thanks!
Old Apr 16, 2021 | 10:20 AM
Acura TL Builder's Avatar
Do not flush the auto tranny on a TL.
Old Apr 16, 2021 | 10:38 AM
Get a Mityvac and pump it out of the dipstick hole.
Old Apr 16, 2021 | 11:27 AM
What I don't understand is how 'the shop' cannot remove this little ole thing (90081-PX4-003):
Unless it is stripped?
Old Apr 20, 2021 | 08:00 PM
Cheekeman's Avatar
I took it to 2 places now.. the shop i got the car ok the road said they were afraid they will crack the transmission and the other (an acura dealership.. only was there to order a part) and they said the same thing. Neither tried anything other than just tugging on it. No thread buster or anything.
Old Apr 20, 2021 | 08:56 PM
Sorry to hear.
Looks like thoiboi's recommendation is the path to follow?
Old Apr 20, 2021 | 09:09 PM
Cheekeman's Avatar
Sorry to hear.
Yeah might have to go that route. Thanks.
Will this one suffice? https://www.canadiantire.ca/en/pdp/d...-0283009p.html
Old Apr 20, 2021 | 11:02 PM
https://smile.amazon.com/Mityvac-720...8977729&sr=8-2
I use this one personally but feel free to use whatever works
Old Apr 21, 2021 | 04:39 AM
Cbble's Avatar
Wow.. I only had to use a breaker bar to break-loose maybe I was dumb and didn't think about the possible damage.. My first attempt was probably13 years ago and hasn't been an issue since then. Maybe try to use a torch or heatgun?
Old Apr 23, 2021 | 05:30 PM
Karanx7's Avatar
Unregistered Member
If more than one shop and a dealership said they wouldn't do it, please don't try it yourself. Mechanics aren't known for being gentle, so they definitely already tried using more force than they should have. If they are worried about the trans casing cracking, they already slipped a pipe over the breaker bar. I honestly don't see how that bolt can hold so much torque, but I'd just consider it welded to the casing now.
Old Apr 24, 2021 | 07:13 AM
So.. no picture of the bolt?
Thread breaker, $25 Home Depot heat gun and a breaker bar will do it. It’s steel vs aluminum, and your on the side of steel.
You will win, put in some effort.
06TSXeer
Apr 19, 2021 04:28 AM
adlx21
May 17, 2008 08:10 PM
NauTiC*
Oct 7, 2005 12:47 PM
KJ32
Sep 14, 2004 12:45 AM
mister2
1G TL (1996-1998)
17
Nov 28, 2002 07:25 AM
