Trans Fluid
Old Nov 15, 2013 | 04:07 PM
BetterBob's Avatar
Trans Fluid
While i was getting my idiot light checked out, i grabbed stuff for an oil change and half of a trans flush.
Will this fluid work, or did i just waste some money?
Valvoline - Import multi-vehicle - Full synthetic ATF
I just know this trans is well.. obtuse, and i don't want to mess it up.
Old Nov 15, 2013 | 04:12 PM
Skirmich's Avatar
Nooooooooooooo............ Do a 3x3 with HONDA GENUINE "DW-1" ATF ASAP!! You don't want to mess with the generic stuff on these trannys.
Old Nov 15, 2013 | 04:23 PM
BetterBob's Avatar
Ok, Thanks for the 1,000th time. I'll hit the honda-acura shop tomorrow and get the real stuff.
Can i still use this to flush my power steering?
Old Nov 15, 2013 | 05:15 PM
Skirmich's Avatar
Yes any ATF! is good for the Power Steering tough what a waste of money!! You don't have the receipt to return them?
Old Nov 15, 2013 | 05:23 PM
TLer trash's Avatar
Just return the atf. Don't put anything in a honda power steering system that doesn't say it's approved for that purpose. You're better off putting it in the trans.
Old Nov 15, 2013 | 05:29 PM
Skirmich's Avatar
^ Its for the flush to the P/S system he don't mean to replace the P/S Fluid itself with ATF.
You use ATF in the P/S as a detergent flush.
Old Nov 15, 2013 | 05:53 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Fill it thru the dipstick so you wont have to mess with the oil jet, Although its slower.
Old Nov 16, 2013 | 04:52 AM
BetterBob's Avatar
I have an internal jet, so i can fill it with standard fill procedure. I'll take the unused ATF back.
Old Nov 16, 2013 | 06:59 AM
3.2TLc's Avatar
When ya take the fluid back, check on an external "spin-on" ATF filter.
Old Nov 16, 2013 | 07:43 AM
BetterBob's Avatar
I was considering that. Will do. Thanks.
Old Nov 16, 2013 | 09:53 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Lucky you, I assumed you had one since you have a 2000.
Old Nov 16, 2013 | 10:09 PM
BetterBob's Avatar
I returned it all, and put in spec.
Shifts like I was on the clutch.
It's a beautiful thing.
Old Nov 21, 2013 | 05:59 PM
01tl4tl's Avatar
were you getting any trans dirty selenoid symptoms?
= at very light throttle coming off a stop- a light shudder in shift from 1-2?
any probs? or just a maitenance change to the new formula dw1?
did you do the drain and refill once, or 3 times with 5 minute drive between?
use nothing but HONDA PS fluid in the TL ps,,its VERY picky about that!
note on flushing ps, ck www.seafoamsales.com tech section for its use in ps
also get 5 foot garden hose with ID dimension to match OD of lower ps hose at res.
CLAMP the hoses together after slip fitting together
or I can assure you of a major mess
Old Nov 21, 2013 | 06:05 PM
01tl4tl's Avatar
note: place some cardboard under front wheels to reduce friction to ground surface and leaving black crop circles on the driveway
flushing ps requires engine running- turning the wheels full lock to lock repeatedly to force fluid out of hiding
until its empty!
refill and start engine- keep refilling and turning - then drain as you turn etc
the procedure is in owner book or diy section,,may take a few refills and drains to get it clean
Old Nov 21, 2013 | 06:46 PM
BetterBob's Avatar
I thought i was supposed to drive it for a week between 3x3 changes...?
So that the trans fluid gradually changes to "new".
Old Nov 21, 2013 | 09:20 PM
Yikes's Avatar
You can. When I did my 3x3 I did it over three days, but not because I wanted the transmission to adjust. I just felt lazy. To my knowledge there isn't a set time you have to wait between every 1x3.
Old Nov 21, 2013 | 09:34 PM
RONE's Avatar
Dirty solenoid? Have any more info on this? I've had a shutter on the 1-2 shift for a while that I assumed was the start of my transmission going out again. If I can instead clean up a solenoid or two, that would be awesome!
Old Nov 21, 2013 | 09:41 PM
BetterBob's Avatar
I don't think there is really anything you can do for a bad/gunked up solenoid except change the fluid, filter, and pray.
Oh, and i just had hard shifting, no slippage. All of my "idiot" lights have been addressed.
Thanks to 01tl4tl for the suggestion on the P/S flush.. But does you username say "2001 TL For The Loss"?
fsttyms1's Avatar
Actually the more i have read on BITOG, the Valvoline fluid seems to be a good fluid for our trans.
Old Nov 21, 2013 | 09:42 PM
fsttyms1's Avatar
You can take it out and clean the screen on it. Many have found them to be clogged/clogging up.
Old Nov 21, 2013 | 09:52 PM
ErickUa5's Avatar
Mr.Helpful Diagram
My way of dealing with the slight shutter is to put the shift gate in D4 it magically disappears. This works for me even though I checked every solenoid/filter and drain and fills and nothing looks bad.
Old Nov 21, 2013 | 09:54 PM
BetterBob's Avatar
Ok, What's BIOTG?
And where is this screen you speak of?
Old Nov 21, 2013 | 10:05 PM
BetterBob's Avatar
On an unrelated note.
I know when i first bought this thing, i accidentally put the trans in manual mode. I thought "This thing shifts weird".
However, further reasearch reveiled that I was a retread.
Old Nov 21, 2013 | 10:35 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Ok, What's BIOTG?
BITOG is Bob Is The Oil Guy its a good site.
Every solenoid you see on the tranny has one.
Old Nov 21, 2013 | 11:16 PM
BetterBob's Avatar
Ah, good.
That should keep the wife off me for another 3-4 months.
"I'm reading about the car" seems to have worked well so far.
Old Nov 29, 2013 | 11:12 AM
01tl4tl's Avatar
ck our diy list/search for for trans pressure switch or shift selenoid
there are 2 you can access externally and replace or clean
requires agile hands and removal of 3 layers of skin to reach iirc
Old Nov 29, 2013 | 11:15 AM
01tl4tl's Avatar
if you dont have the original owner book go to www.owners.acura.com and register with VIN, get free download of owner manual with great operating tips in it
plus safely store radio nav codes and look up lots of info about your specific car
the- Im looking up something about the car- works well at my house too~
note the owner book details a 3x3 atf change
Old Nov 29, 2013 | 03:40 PM
Nicks2001tl's Avatar
Regarding a 3x3 transmission fluid change.
You have to buy more than 9 quarts because more than 3 quarts come out at a single time. 10 quarts to be able to keep the dip stick at in between the fill lines.
Between each flush drive the car around going through all the gears before doing another flush.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
