Tranny fluid question
I was low on fluid last week and added 1/4 quart of dexron III. Should I now flush and fill or just replace and fill? I have an 03 tl with 30K miles
Thanks much!
Thanks much!
if you have 30K miles and never changed your tranny fluid, it is porbably a good idea to do so.
Make sure you use Honda fluid. Given all the tranny problems and warranty issues, I'd recommend sticking with Honda fluid and keeping all the receits.
btw, I don't think 1/4 qt. of dextron is significunt to cause a problem.
Originally Posted by cjde2006
Thanks.....local Acura dealer does flush and fill for 99.00. I will do that
Originally Posted by acurabum
How do you know the ATF level was low ? ATF dipstick ? It'a not mormal that TL burn
ATF..............
ATF..............
Originally Posted by fsttyms1
Another question is how did you check the fluid to know its was low. did you do it running car off, fluid hot or cold?
I need 2 more gears
4.99-5.99 a quart is the price at most acura dealers. I honestly don't think Honda Z1ATF is very good tranny fluid. I am seriously considering trying either Redline ATF or BG Syn ATF, both are very reputable companies and claim their fluid is far superior to anything else out there. I have a 99 with the 4spd and believe that the greater oxidation, anti-corrosion and great fluid viscosity range would benefit the 4 spd tranny a great deal. Has anyone used either of these fluids and what was your experience.
I need 2 more gears
i have a long commute to work each day 35 miles one way, when I get home I check my tranny fluid and oil once a week. When I was checking my tranny fluid in dec., jan, feb, march it was always clean because I did a drain and fill in dec., but in april it was a little dirty, may it had some metalic color and extremely fine flakes, now in june it has gotten progressively worse. I did a drain and fill with 3x w/9qrts of Z1 in dec. BTW. I have been thinking strongly about changing to a different tranny fluid. I am looking for someone here that has used or is using either Redline ATF or BG Syn ATF to see if they noticed any difference after they switched. I don't expect a miracle but the 2 companies I named are very reputable and I tend to believe their claims over those of others, of course I could be wrong and their ATF's may be junk, but I doubt it.
On the way!
Originally Posted by DudeLuv
Didn't know that....thought it was just the opposite....false reading when off.
'02blAcuRAT!! soooCool!!
Originally Posted by fla-tls
Yeah. 80%+ of transmissions out there are checked while on. Late model Hondas and Acuras aren't.
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
BTW, Also just checked mine both ways, on and off....same reading.
On the way!
Yeah - Dodge and Jeep RWD models are all checked in neutral, many GM derivative (4L-30) trannys and all BMW 5->7 series (and land rovers) {ZF units} are all checked under the vehicle (no dipstick).
There's always a twist...
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
HeloDown
09-08-2015 06:51 PM
