Tranny failure
Old Feb 17, 2005 | 07:40 PM
chrisholly's Avatar
Tranny failure
I just bought an 02 TL and have been worried about the tranny failure and everytime I feel anything I think it's my transmission. How did you know when your transmission was acting up and what should I watch out for? Is there anything I need to do prevent?
Old Feb 17, 2005 | 11:45 PM
alleyesonmeee's Avatar
MIA
Common signs of transmission failure are:
An abnormally loud noise from the transmission.
Extremely slow or delayed gear engagement, upshifts, or downshifts.
Abnormal gear slippage during upshifts or downshifts.
Erratic or excessively harsh shifting.
Automatic transmission fluid (ATF) leaks.
While driving, the D5 indicator on the instrument panel flashes.
These characteristics are normal; they should not require you to call your Acura dealer:
Quick downshifts. The transmission has a computerized control system called grade logic. When going down a hill, even a light touch of the brake pedal can cause grade logic to downshift to the next lower gear. Downshifting helps to slow the vehicle through engine braking.
Does not always shift through the full range of gears. This can also be caused by the grade logic system keeping the transmission in the optimum gear for different driving conditions.
Mechanical noise when selecting a forward or reverse gear. It's normal to hear a slight mechanical noise when moving the shift lever from one gear to another. This noise can sound abnormally loud if any of the windows are down and you are parked next to a wall or another vehicle.
Vehicle may not hold its position when stopped on an incline in gear (may roll backward when the brake pedal is released). This can occur on most Acura-made vehicles. It is one of the measures used to improve fuel economy.
Hard shifts before the engine warms up. By design, the transmission shifts a little harder when the engine is cold. It returns to smoother shifting when the engine warms up.
Make sure you have your transmission fluid checked every 10,000 - 15,000 miles and flushed if it is burnt. Also, put the parking brake on when you park the car to take stress off of the transmission. Other than that, there isn't much you can do.
Old Feb 18, 2005 | 07:36 AM
Shift_it's Avatar
Great info alley. I think this should be a STICKY? Admins?? What'cha think?
Old Feb 18, 2005 | 07:44 AM
MikePA's Avatar
This information is right from the Acura Owners site. Click on the Extended Warranty for the transmission recall notice.
Old Feb 18, 2005 | 09:33 AM
MIA
Old Jun 18, 2005 | 08:38 PM
WHITE3.2TL-S's Avatar
yes the D5 light is blinking while i drive and teh traction, check engine and oil light are on...trannny or modulator?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
