Tranmission Oil...
Thass Wassup!
Tranmission Oil...
So I was reading up on Redline High Temp ATF. I'm due for my transmission drain and fill from the break in of the new transmission I got last month. Should I switch to this or should I stick with the Honda ATF?
In the TL automatic transaxle we recommend the D4ATF a suitable replacement for the ATF-Z1 fluid. The High Temp ATF is a higher viscosity fluid typically used in extreme applications where additional viscosity at elevated temperature could be beneficial. The higher viscosity though can alter the shift characteristics causing a delayed and firmer shift at lower temperatures.
Regards, Dave
Red Line Oil
Regards, Dave
Red Line Oil
Regards, Dave
Red Line Oil
Regards, Dave
Red Line Oil
Thass Wassup!
I'm so lost. lol What would be a proper replacement? And Raj, I was told to do a drain and fill after 1500 miles of the reman transmission being in my car to remove any metal particles that may have come off and went into the oil.
CL-S469
2G CL Transmission Recall Q & A
Aug 17, 2003 11:25 AM
