Toe in&out
Old Nov 30, 2000 | 08:36 AM
HOT's Avatar
HOT
Question Toe in&out
what's gonna happen if i dont adjust toe in&out after lowring? fossible to feel vibration? Normal tire shop won't do the allignment cuz my car is out of factory spec? 18"+lowered. They said i need camber kit to do an allignment. without it they cant do it?
So how does this allignment thing exactly work? How can Dealers do when the camber is NOT adjustible????? any1???
Old Nov 30, 2000 | 05:03 PM
TommyAmrani's Avatar
Post
he HOT, same problem here, sam... you got mail bro
Old Nov 30, 2000 | 11:07 PM
HOT's Avatar
HOT
Post
so nobody knows how Camber, toe in&out works????!!
Old Nov 30, 2000 | 11:46 PM
AcuraTL's Avatar
OG
Post
If you used Comptech springs, the camber should still be within factory specs. The camber on the TL is not adjustable, if yours is really out of specs, you might want to consider buying the camber adjustable kit from Comptech. As for toe in/out, they can adjust those even when the camber is out of specs.
Go to another alignment shop.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old Dec 1, 2000 | 12:14 AM
ChrisK's Avatar
Post
When you lower the car, not only does it go into negetive camber, but also Toe Out. If you only fix the Camber, you will still wear down the inner side of the tires if you left your car at Toe Out. Personlly, I would at least get you Toe alignment fixed, then worry about the camber correction kit.
Chris K.
Old Dec 4, 2000 | 11:00 PM
HOT's Avatar
HOT
Post
So What exactly Dealer's DO? when they do an alignment job???? Camber is NOT adjustable right? so they just do Toe In&out??? that's it???
Old Dec 5, 2000 | 10:32 AM
RichWDP's Avatar
Post
I had Comptech springs installed;
Camber stayed within spec, but toe in/out was off.
Wait a couple of weeks after spring installation (settle in) before getting the toe adjusted.
Old Sep 13, 2004 | 12:17 PM
99TLHeather's Avatar
Hey guys, I need some advice. I just got my toe in/out corrected from an alignment shop and it ended up with -.01 for my left wheel and .01 for my right wheel. This is within specs but shoudn't it be somewhat close to being the same? Should I go back and make him redo it?
Thanks for any advice!
Old Sep 13, 2004 | 12:32 PM
MADCAT's Avatar
If you go below 1.5 inches, then you need a camber kit.
Old Sep 13, 2004 | 12:56 PM
Pure Adrenaline's Avatar
Dragging knees in
I didn't realize that lowering the car changed the toe settings. :P
It only changes the camber settings. Get a camber kit and get an alignment.
RichWDP -- Chances are that your toe was already off before installing the springs. Lowering springs don't affect toe.
Old Sep 13, 2004 | 03:10 PM
patrick's Avatar
Other reputable brands for camber kits include: SPC and Ingalls.
Old Sep 13, 2004 | 06:37 PM
Mr Hyde's Avatar
Taking apart your suspension to install springs can knock some alignment specs off. Toe is especially one of them. Alot of people dont get an alignment, wear out the insides of their tires due to toe , and incorrectly blame camber.
A little reading on camber, toe, thrust, etc
http://www.tirerack.com/tires/tirete...eral/align.jsp
Old Sep 14, 2004 | 12:44 AM
NYZGREATST's Avatar
Sig Rho's Finest
i thought it was if you lower past 2 inches you would need a camber kit
oeasley
Jun 24, 2017 06:45 PM
advan031
5G TLX Photograph Gallery
Nov 14, 2015 07:44 PM
lanechanger
Oct 13, 2015 10:56 AM
Sunnyj209
ILX
Sep 30, 2015 09:31 AM
kixo
Sep 5, 2015 08:54 PM
